I got the second set of carbs on and dialed them in as good as I could when I found out that I was out of propane. Also, the spring was missing that holds the main idle adjustment still. I pulled the spring off the first set of carbs and am charging the battery real good at the moment. Before I button it up I do want to get some propane and make sure that the idles are as good as I can get.
All of the spark plugs are firing now and look OK without a real world load on them. I need to get insurance and a tag before that 20 minute ride that I have been waiting for.
Also, T. C., I don't mind putting the other coils in that I pulled from the 81 XJ....I just need to know if the XJ's used the resistor or not. If it did then I don't need to waste my time, if it didn't then those should be better than what I have and now is the time to put them in.
While I am writing, I checked the first set of carbs and on the 78 carbs I think that the spring is below the washer and mine is. I also had all of them set to the center position. When I use these carbs again on my next project then I might consider moving that setting for this one carb if it continues to have a problem with richness.
So far this and last year I have purchased 4 motors, 3 frames w/wheels, 3 exhausts, 2 carbs and 2 handlebars.... I plan on riding this first bike while I get a second going. It would be my keeper since it looks better.
