If it runs well enough to take it for a 15 - 20 min. ride to really warm the whole engine up you'll get a better synch
You could synch it and then move the hoses to different carbs to see if the gauge holds steady.
GL
GL
	 It doesn't reach full charging rate/potential until 2500 rpm or above!  So...you might want to put a jumper from a car battery or jump starter booster battery to help keep the system voltage up while idling!
