81 mns
  • foreda
    • 949
    • Southwest Louisiana
    81 mns
    Lookey what I found about 15 miles from my house. Bike has been setting for a long time but has only 6k miles. I am going look at it Friday. Hopefully it will be in my stable by the weekend.
    Dale
    78 XS1100E Standard
    Coca Cola Red
    Hooker Headers
    1979 XS1100 Special
    1980 XS Standard
    2006 Roadstar Warrior
    Nice find, but I'm sure you noticed that it doesn't have OEM pipes, those are kerkers, but still nice and black! Also not oem shocks. Lockhart Oil cooler also. Have fun!!
    • foreda
      • 949
      Not stock
      Yes I did notice this plus some other stuff but if I can get it for a reasonable price, I'll take care of most of the non stock stuff except of course the exhaust. I will try to find a stock exhaust in reasonable shape and have them ceramic coated black. I 've never done a MNS and look forward to it although it is second in line to the Honda V65 Magna I am restoring now.
      78 XS1100E Standard
      Coca Cola Red
      Hooker Headers
      1979 XS1100 Special
      1980 XS Standard
        • 3193
        Check the shape of all the gold trim. It is almost impossible to replace although it can be done with considerable expense. If the gold trim is questionable then you need/want to get it cheaper. Even the swing arm covers need to be in excellent shape to command a top dollar, just so you have some ammo for the seller!
        • mack
          • 2411
          • Ontario, Canada
          Good luck
          Nice find. In general I found when I did mine that it was more labour intensive to deal with the black motor and other stuff. Gold will be an issue as rasputin said and the non OEM parts should provide some barganing room. With the milage on it, you sure can't go too far wrong.
          mack
          79 XS 1100 SF Special
          HERMES
          original owner
          81 XS 1100 LH MNS
          SPICA
          78 XS 11E
          IOTA
          https://youtu.be/wB5Jfbp6SUc
          https://youtu.be/RaI3WYHSuWA
          Frankford, Ont, Canada
          613-398-6186
          • foreda
            • 949
            Gold trim
            What did you guys do with the gold stuff? Is there somewhere I can buy the trim or have it made?. What about getting the metal anodized gold? Anyone ever do this?
            78 XS1100E Standard
            Coca Cola Red
            Hooker Headers
            1979 XS1100 Special
            1980 XS Standard
            • mack
              • 2411
              • Ontario, Canada
              Gold trim
              I had mine all re-chromed in 10K gold/brass mix. Came out really good but it was pricy. I looked into "old brass" dipping as well. If you did it all at the same time, the appearance would be really close to the original. I didn't go with it though because I've seen door handles, knockers and exterior lights etc. that have that finish on them and it wears off quickly and turns black in a few years. However, considering they are exposed to the elements 365 days a year, it might be ok for a bike that spends most of the time out of the sun and rain in a shop or garage. Which is probaly the case with yours, I know when you have more than one bike which both of us do now, it's hard to clock a lot of miles on any of them.
              mack
              HERMES
              original owner
              81 XS 1100 LH MNS
              SPICA
              78 XS 11E
              IOTA
              613-398-6186
              • foreda
                • 949
                Pricey
                Where did you get yours done? How pricey are we talking abou?
                78 XS1100E Standard
                Coca Cola Red
                Hooker Headers
                1979 XS1100 Special
                1980 XS Standard
                • mack
                  • 2411
                  • Ontario, Canada
                  Gold trim
                  I'd have to dig around for the receipt, but I think it was around 8 hundred. I had a lot done though, all the gold including the screws etc and I think ten carb tops done at same time. It was guy in Ottawa Canada. He was the only one up here in my area that does it the old way(right) that hasn't been shut down by the tree huggers.
                  mack
                  HERMES
                  original owner
                  81 XS 1100 LH MNS
                  SPICA
                  78 XS 11E
                  IOTA
                  613-398-6186
                    It's possible that foreda might have a little less tree hugger problem if he can find somebody in Louisiana to do it.
                    • foreda
                      • 949
                      Plating
                      Hopefully. I'm looking!
                      78 XS1100E Standard
                      Coca Cola Red
                      Hooker Headers
                      1979 XS1100 Special
                      1980 XS Standard
                        He'll have less trouble finding somebody to do it, but I doubt if it'll be any cheaper...
                        • foreda
                          • 949
                          Midnight Special
                          I did not buy the first one I posted but I bought this one. I'm trying to get it shipped from Michigan and hopefully get it in a couple of days. This one is a 1980. Anyone with tips for restoration would be appreciated. Main thing will be getting the gold replated and anyone with any information on this would be helpful. Not sure how bad or good it is until I put my eyes on it but this one will get the full resto.
                          Dale
                          78 XS1100E Standard
                          Coca Cola Red
                          Hooker Headers
                          1979 XS1100 Special
                          1980 XS Standard
                            • 3193
                            If you are into a full resto with as many stock parts as you can keep, be very careful with the rear MC as there are no longer any rebuild kits that I am aware of for it. I did manage to find one a couple of years ago so i grabbed it and did not use it till now but I do know they are extremely rare.
                            Check on Mack's posts about his bike as he did a wonderful job of his resto and did the gold and all.
                            • mmatches1
                              • Sep 2012
                              • 121
                              • Alberta, Canada
                              Interesting that the lower fork is black. Is this common for 81 Specials? My 81H has Special lower forks but they are silver.
                              81H Venture - hope to ride summer 2013
                              79F Cafe Racer at Some Point;
                              68 CB175 Sloper - Cafe Racer
                              74 KZ400 - Restoration project nightmare
                              62 BSA Super Rocket - In Pieces
                              72 CB100 Super Sport - Not super or sporty but fun
