Pilot screw
  • LoHo
    • Sep 2002
    • 1342
    • Fresno, CA
    Pilot screw
    Say gents, what's a good starting spot for the pilot screws? If the damned bike ever starts, what criteria would I use to adjust the pilots? Vacuum? Colortune? Prayer?
    1980G, stock everything.
  • CaptonZap
    • Jun 2010
    • 1748
    • Denver
    Whoa, Dude!
    What happened with the sticking carb slides? You can't just skip around like that, you'll confuse us.
    One thing at a time.
    CZ
    • LoHo
      • Sep 2002
      • 1342
      • Fresno, CA
      But, geez, Cap...I, of course, took your advice and checked my diaphragms and springs, finding the two quick ones had folded a bit as I put them back together. When those were done, all the slides held or dropped slowly with the hotdog hole blocked, just as you said.
      Full of confidence, I hooked everything back up, put in some new gas, got all my riding gear on, and hit the starter, which granked and cranked, with an occasional pop, but no joy.
      Just now, I produced a 12 gauge-quality backfire, so I'm fishing for answers...again.
      • mack
        • 2411
        • Ontario, Canada
        Probably
        2 1/2 to 3 turns out from lightly seated will get it to run well enough to colour tune. Put a couple hundred miles on it, then check your plugs. They are a better indicator then anything else.
        mack
        79 XS 1100 SF Special
        HERMES
        original owner
        81 XS 1100 LH MNS
        SPICA
        78 XS 11E
        IOTA
        https://youtu.be/wB5Jfbp6SUc
        https://youtu.be/RaI3WYHSuWA
        Frankford, Ont, Canada
        613-398-6186
        • LoHo
          • Sep 2002
          • 1342
          • Fresno, CA
          Mack, I think the farthest I could push it would be five or six miles. It would be a good workout, though.
            • 2104
            Sounds like something is outta time.
            • tarzan
              • 1700
              • Chandler,Az.
              Or it could just load up and backfire on an occasional spark. It could be caused by a few different scenarios.
              80 SG XS1100
              14 Victory Cross Country
              • CaptonZap
                • Jun 2010
                • 1748
                • Denver
                Thanks, that's better,
                Now we know where the carbs stand. Well, since you had the tank off, were you messing with the wiring to the coils? The left coil has an orange wire to it, the right has a gray wire to it. The left one fire plugs 1 and 4, and the right one fire 2 and 3.
                Check that, then check back.
                Once again, we'll wait.
                • mack
                  • 2411
                  • Ontario, Canada
                  Your right LOHO they are a heavy old brutes. If you could push it 5 or 6 miles my hats off to you. If mine ever break down that far from help, I'm pushing it as far as a ditch and camoflaging it until I can get a trailer to get it home.
                  As to your problem, check for spark, fuel and make sure there isn't any mice living in your air box. After you determine these things, it's a simple matter of getting them all to the same place at the right time. Simple eh!
                  mack
                  HERMES
                  original owner
                  81 XS 1100 LH MNS
                  SPICA
                  78 XS 11E
                  IOTA
                  613-398-6186
                  • LoHo
                    • Sep 2002
                    • 1342
                    • Fresno, CA
                    Mack, you're making it too hard on yourself. Just be careful to always break down uphill of your destination and you'll be fine...sort of.
