Help! No clutch action.
  • conquest87tsi
    • Jun 2012
    • 190
    • Jackson, Minn.
    I recently bought a '79 standard that is need of a little work. When loading it up I noticed that the clutch didn't work. I.e. doesn't disengage when the lever is pulled. The part that concerns me is that the PO says he replaced the clutch.
    I started investigating today and found the cable linkage and everything up to the clutch seems correct. I was wondering if anyone has ideas before I disassemble the clutch.
    Thanks
    1979 XS1100 SF
    1979 XS750 SF
    Previous Rides:
    1981 KZ650CSR
    2006 VTX 1300C
    1986 Radian 600
    The plates are probably just stuck from sitting so long. If you rock the bike back and forth in 5th gear it may free them up. Another way (be careful) is to start the bike in neutral, while sitting on it in an open area as if you are to ride away, drop the shifter into first and take off, that will usually free it.
    • mack
      • 2411
      • Ontario, Canada
      Frozen clutch plates
      Yep, sounds like frozen plates. As phil said, turn on the key and rock it and change gears till you find a green neutral light. Let if warm up and pull the clutch leaver in and hold it for a while, couple minutes anyway. Sometimes it will just take a while for the oil to work its way in there. If you try first gear and it stalls again, then get it back in neutral and have someone give you a push while it's running (these are heavy dudes) and then shift into gear again. It won't stall this time and you can give it some throttle, pull in on the clutch lever and slam on the rear brake. That will separate the plates. Slip clutch it for a mile to allow the oil to get into all the friction plates, after that and it should be freed up by then. You'll know when you try to turn around if it has or not. Repeat as required.
      mack
      79 XS 1100 SF Special
      HERMES
      original owner
      81 XS 1100 LH MNS
      SPICA
      78 XS 11E
      IOTA
      https://youtu.be/wB5Jfbp6SUc
      https://youtu.be/RaI3WYHSuWA
      Frankford, Ont, Canada
      613-398-6186
      • conquest87tsi
        • Jun 2012
        • 190
        • Jackson, Minn.
        Thanks fellas, Ill have to give it a try once I have everything back togther. Well by then there will be half a foot of snow on the ground.
        Guess this doesn't surprise me as there was only like half a quart of oil in it when I picked it up. So the clutch was completley dry for a year or more.
        1979 XS1100 SF
        1979 XS750 SF
        Previous Rides:
        1981 KZ650CSR
        2006 VTX 1300C
        1986 Radian 600
          If your feeling up to it, an alternative is to pull the clutch and lightly sand both plates and the friction disc. Something to do while your waiting for the snow to clear. It will also give you a chance to make sure all the C-clips are in place, and the countershaft bolt is in good and tight, and that the PO folded up the but retainer clips on the clutch nut.
          • Yard Dogg
            • Mar 2010
            • 884
            • Tri-Cities, Wa
            Right, and while your at it that, you can grind your gear doggs and slots. Make sure the tranny is good to go.
