Not easily, and you'd lose the air assist.
You could close the 'balance' holes in the tubes with a spot weld (the fork tube is too thin to tap/seal at that point), but the fill point for the air is also incorporated into the balance tube, so you'd lose that. The fork caps have the adjustable dampers knob, so no drilling them for an air inlet.
And being unable to add air, you'd have to increase the fork oil amount (reduce the air volume in the fork) to compensate for the lack of air pressure. But that will only partially 'fix' the problem; the air-assist forks use softer springs, depending on the air pressure to make up the difference, so a swap to higher-rate springs will be needed.
There is one possible way to install XJ forks onto Special trees without moving the ignition switch or major mods to the forks. Close the OEM holes on the tubes, then drill new ones right above the lower tree. Slide the balance tube down, then shorten the headlight ears. I think you'd have to rework the headlight adjustment bracket a bit, but that might work. I will note one thing here; the existing balance tube holes are located in a 'dry' area (above the fork oil upper level), this will put the holes into a 'wet' area and leaks are a possibility.
You can swap either LH or XJ lowers onto the 'regular' Special forks as the internal machining is the same. The XJ forks have that 'indexing' screw for their dampers, you can shorten that, and they use a different seal/dust cover from the Special forks. All the other Special internal bits will fit...
