Sandy Devastation
  • Eastcoaster
    • Jan 2012
    • 508
    • oceancity NJ
    Sandy Devastation
    Thought it best to move the resurrection of my Sandy Now Project Bikes here. I have been soaking the carbs for about a week now. I just can not seem to get the butterflies to move at all I am afraid to force them to much. Anyone have any thoughts on getting them to move? Thanks Gordon
    82 XJ1100J
    81 Venturer
    • 3932
    What are you soaking the carbs in? Berryman's? Pinesol?
    • Eastcoaster
      • Jan 2012
      • 508
      • oceancity NJ
      Soak
      Pinesol change out every other day Hit with some spray and oil while out of the bath and run in hot water and back in fresh soak
      82 XJ1100J
      81 Venturer
        Hopefully not Berrymans as that will eat the shaft seals. If they're really frozen, I'd split the rack if you haven't already done so and 'work' each one individually. This can take a while, be patient....
        • WMarshy
          • Apr 2009
          • 2402
          • Mexico NY
          Might try some break cleaner on the seal. Just a little bit should make the rubber shrink a little. Try this last as you dont want to ruin the seal but if your at the point where your about to replace them then I would give it a try.
          '79 XS11 F
          Stock except K&N
          '79 XS11 SF
          Stock, no title.
          '84 Chevy K-10 "Big Blue"
          • GLoweVA
            • Jun 2011
            • 1957
            • Virginia Beach, VA.
            When I first got my SG, my butterflies were stuck too. (maybe not as bad as yours are though)
            I ended up using carb cleaner in the can and spraying the heck out of them and used a crescent wrench on the shaft (where the sync adjustment screws are) and worked them back and forth al lot until the rotated fully.
            Gentle pressure at first to get them moving a little then as things seemed to loosen up, back and forth, back and forth.
            I tried breaking the rack up, but I didn't have an impact screwdriver, so I couldn't break the rack screws loose.
            Once one started to move and the other ones next to it didn't you could see the sync adjustment spring squish in the shaft holder there.
            80G (Green paint(PO idea))
            The Green Monster
            Got him in '04.
            bald tire & borrowing parts
            Scarlet
            Got her in '11
            Ready for the twisties!
            81H (previously CPMaynard's)
            Hugo
            Cold weather ride
            • Eastcoaster
              • Jan 2012
              • 508
              • oceancity NJ
              No Budge
              No doubt I got to crack this rack The carbs are cleaning up nice but no movement also the enrichments won't move todays project. Thanks for the help
              82 XJ1100J
              81 Venturer
              • Eastcoaster
                • Jan 2012
                • 508
                • oceancity NJ
                Unchartered waters for me
                Ok first off the rack after a fight with channel locks and WD40 I got very hard movement I can get the screws out of the butterfly. Should I remove it and try to drive the shaft out?
                82 XJ1100J
                81 Venturer
                  I would try everything else to get thing moving first before trying to remove the shafts.
                  • Eastcoaster
                    • Jan 2012
                    • 508
                    • oceancity NJ
                    5000 wiggles
                    Yup i got the first one going onward to the rest
                    82 XJ1100J
                    81 Venturer
                      Better count better next time. I bet it was more like 5007 wiggles!
                      • Yard Dogg
                        • Mar 2010
                        • 884
                        • Tri-Cities, Wa
                        Carefull. Make sure you check for any burrs on the sharp edges where the butterflies screw on to the shaft. I made the mistake of not checking it once and it damaged the hole in the body where the shaft runs through.
