Vacuum and fuel line question
  • copeland3300
    • Apr 2012
    • 50
    • Ft George G Meade, Maryland
    Hey guys. I'm almost done putting everything back together on the bike. The last thing I'm trying to figure out is the vacuum and fuel lines. I think I know where they go, but I've not had much luck with an exact answer.
    Based on my picture
    A - crankcase breather (I have to get a filter)
    B - Left fuel line, goes to fuel petcock
    C - Right fuel line, goes to fuel petcock
    D - Vacuum line, connected to the carb holder on cylinder 2. I have no idea where it goes.
    E - Vacuum line, connected to the carb holder on cylinder 3. I have no idea where it goes.
    Also what seem to be nipples that could run lines from the carb holders on cylinders 1 and 4 are capped off. I assume I leave them that way?
    Thanks!
    1980 XS1100G - Coming together
    1979 XS1100 Midnight Special - Still in one rusted piece
  • dpotter58
    • Aug 2004
    • 1866
    • Southern Maryland
    Based on my picture
    Thanks!
    vacuum lines to your petcocks? Do you have one to your vacuum advance?
    1980 LG
    1981 LH
      Thanks!
      D and E connect to the petcocks, assuming you still have the OEM standard tank and petcocks. This is the vacuum supply that operates them. The two 'leftover' nipples remain capped, unless you're syncing the carbs, then this is where you connect the gauges (after disconnecting the lines to the petcocks).
      • copeland3300
        • Apr 2012
        • 50
        Oh, ok, well that was an easy answer then :P
        dpotter58, can you expand on the vacuum advance question? That's on teh left side of the engine, right?
          Yes, the vacuum advance is under the left side engine cover. There is a brass nipple on the #2 carb body. That is what the vacuum advance must be connected to.
          • copeland3300
            • Apr 2012
            • 50
            Nice, thanks!
            • copeland3300
              • Apr 2012
              • 50
              So after doing a little more research, I'm assuming that
              A) because I don't recall seeing it
              B) because it seems to be for an SF
              I don't have an octy on an '80G?
              • dpotter58
                • Aug 2004
                • 1866
                • Southern Maryland
                nope. they are only on the specials
                1980 LG
                1981 LH
                • GLoweVA
                  • Jun 2011
                  • 1957
                  • Virginia Beach, VA.
                  The Octy's are for the Specials.
                  If you have the larger standard tank, then you should have vacuum controlled petcocks and thus no need for an octy.
                  Dwayne, you sure do type fast.
                  80G (Green paint(PO idea))
                  The Green Monster
                  Got him in '04.
                  bald tire & borrowing parts
                  Scarlet
                  Got her in '11
                  Ready for the twisties!
                  81H (previously CPMaynard's)
                  Hugo
                  Cold weather ride
                    A shas been pointed out, each model Standard and Specials incorporated a vacuum valve to control fuel flow to the carbs. For some reason that escapes me, Yamaha went with two different designs, one for the Standard models, and another for the Special models.
                    On the Standard models the vacuum valve is integrated into the petcocks, on the Special models it is a separate valve.
                    Why they did not consolidate to one or the other by the 80-81 models I am not sure.
                    • GLoweVA
                      • Jun 2011
                      • 1957
                      Maybe it was a space consideration thing.
                      The special tanks are shorter, so the standard petcock wouldn't fit. (tower's too tall)
                      The special tank also sits a little lower thus closer to the frame and the standard petcock might interfere there.
                      JAT.
                      The Green Monster
                      Got him in '04.
                      Scarlet
                      Got her in '11
                      Hugo
                      Cold weather ride
