Did a dumb thing today. I figure I might as well share it here with the hope that someone else may not make the same stupid mistake.
I have rebuilt many automotive engines in the past, worked on my share of two stoke snowmobiles, but have little experiance with motorcycle engines.
I figure I got decent engine experience. So okay, I pull the head off this beat up, high mileage XJ 1100 after a compression check shows low compression on #1. Take the head to local machine shop and they do a valve job. Okay, looks good.
I decide that before I re-assemble I should check the valve clearance on the bench, so I re-install the cams and turn them to low spots sticking the feeler gage in. Its going well. The springs are pretty stiff when they have to be compressed, but it's okay. I have a wrench the fits on the 7/8 hex on the cam.
What the heck. One of the lifters, springs, and valves isn't coming back up when I turn the cam. I turn the head over and both the exhaust valve and the intake valve are open and jammed against one another. Oh no.
It's a hemi. They occupy the same space when open! Result, ofcourse is two bent valves. They don't seal unless I tap them onto their seats. Will need to go back to the machine shop, and I am sure I'll be in need of 2 new valves and more machine work. There goes another 100 bucks.
Since I have not had the pleasure of pulling a head off one of these beast myself, though I have helped in the process a couple times, have not made that error. But as had been said, your in good company with more than a few who have. Only one cam at a time is the method when they are not connected and in time. That and elevated off the work surface as Moto stated.
, put springs in and remounted the head and compression is back to normal.
