He gents,
My "Interesting 79F" thread has run it's course, now that it is simply an 80G with a 160 MPH speedo.
Pilot jet:
As a preface, the carbs on this 80G have the rubber plugs covering the pilot jet hole, with the passage between the main jet and the pilot jet, if that helps any with the stuff I'm asking below.
-One pilot jet had the screw slot broken/buggered by a previous owner. What is the safest and surest wasy to extract the jet, if there is such a thing as safe and sure existing in the same operation.
Air screw plugs:
-three of the four (#1,#3,#4, I believe) air screw towers on the 80G carbs have a brass something in them flush with the top of the tower, but not the typical plug I'm familiar with that my 80SG had.
These are like donuts, where you can see down into the hole where the air screw is located, not the typical brass cap with the tiny hole in the middle. Is this simply another type of anti-tamper device that I would remove like the plugs I'm used to seeing, or is it something different?
-#2 tower has a brass screw head flush with the top of the tower, and it will turn but not in or out, just spins. Would this be an airscrew that may have already been uncovered, and has vibrated loose to this position, or something different that these particular carbs may have that I am just not familiar with? Just want to be cautious, if you will, and ask.
For what it's worth, this 80G was manufactured in May of 1979, possibly making it an 80 model in the grand scheme thus having different carb plumbing, per se? My 80 SG was manufactured in December of 1979 and has what I consider the "normal" 1980 carbs.
I've searched around a ton on the forum, but can't quite find info to piece together what I'm describing with respect to removing a buggered pilot jet or the type of cap on the air screw.
Thanks much!
Pilot jet:
Air screw plugs:
Thanks much!
