Hey everybody,
I've got 2 questions that I hoping to get a little enlightenment on.
First, I'm going to be starting my grand tear down and leak stopping adventure this week, and I bought new piston rings to go along with all of the new gaskets I got and was just wondering about whether or not I'd have to do a break-in after putting them. I read a whole article on breaking-in the engine when it's brand new (which I'm pretty sure we don't have to worry about here
), and after the cylinders have been honed and new rings installed, but it didn't say anything about just adding new rings. I'd imagine that there would be some sort of a break-in that would need to happen. Has anybody on here done just a piston ring swap that can chime in with some advice?
Second, I'm also planning on blacking out the jugs, and then "shaving" the fins a little to bring the aluminum back on just the tips, but I was wondering about the best methods there too. I was just planning on hand filing them just until I'm through the thin coat of paint, and maybe squaring the edges off a bit, and then following up with a sanding block and progressively finer grit sandpaper until they started shining. Has anybody else shaved their fins? If so, what method did you use, and what recommendations do you have? To me is sounds like "shaving" should utilize something other than a file and sandpaper, and I'd like to avoid taking them to a machine shop to mill them.
Thanks in advance for you input.
), and after the cylinders have been honed and new rings installed, but it didn't say anything about just adding new rings. I'd imagine that there would be some sort of a break-in that would need to happen. Has anybody on here done just a piston ring swap that can chime in with some advice?Second, I'm also planning on blacking out the jugs, and then "shaving" the fins a little to bring the aluminum back on just the tips, but I was wondering about the best methods there too. I was just planning on hand filing them just until I'm through the thin coat of paint, and maybe squaring the edges off a bit, and then following up with a sanding block and progressively finer grit sandpaper until they started shining. Has anybody else shaved their fins? If so, what method did you use, and what recommendations do you have? To me is sounds like "shaving" should utilize something other than a file and sandpaper, and I'd like to avoid taking them to a machine shop to mill them.
