My gas tank derusting nightmare
  • copeland3300
    • Apr 2012
    • 50
    • Ft George G Meade, Maryland
    So as an update, I bought a ton of vinegar at costco for $15, and it did a decent job.
    I then saw a suggestion to use "The Works" toilet cleaner. Awesome stuff. That took care of anything that was remaining, and it was cheap too, I got a gallon (of which I only used about half of) for $10.
    Do I suppose I'm done finally
    1980 XS1100G - Coming together
    1979 XS1100 Midnight Special - Still in one rusted piece
    • latexeses
      • Jun 2008
      • 1491
      • California
      Does anyone but myself think that the chain in the tank might just vibrate and wear a hole through the metal?
      Not going to happen right away but if the tank was rusty how thick might the metal be?
      Everything on hold...
      • copeland3300
        • Apr 2012
        • 50
        Ehhhh, I don't think it should...
        If it does then I'm in the same boat in that I'll have to do some welding to fix it.
          • 5069
          I found a bike key in one of my tanks once. Personally, I would try everything to remove the chain...remove petcock towers, use a wire coat hanger to snag it an move it around, etc. It is probably wrapped around the overflow tube or stuck between that and the tank.
