Nate, normal operating temp is somewhere between 150F - 250F. Your guage may be reading a bit high. Depending on where the sensor is mounted you will get different readings. If you are using a dipstick type sensor, right next to the clutch pack, you may be getting a false reading off of the clutch.
Most of the reading I have done about that points to the fact that an oil temp guage is just another of stress when riding. Something else your paying attention to rather than concentrating on riding. Get rid of it.
If you are using a good quality MOTORCYCLE OIL it shouldn't be a problem because those oils are good up to about 325º and some of the motorcycle racing oils are good to over 400º before they start breaking down.
