Transmission woes.
  • Yard Dogg
    • Mar 2010
    • 884
    • Tri-Cities, Wa
    Transmission woes.
    I took my first ride on this bike today and noticed right away that I have common transmission problems. I was aware that these bikes have 2nd and 5th gear issues, but am wondering if there's anything else I should do while I'm in there to prevent future issues.
    Here's what the bike does. I can grab 2nd, but it pops out, I can't get into 5th at all, and when I slow down I have difficulties getting into 1st unless I'm going slow enough.
    I see the tech tips for 2nd and 5th, but I'm wondering if I may also have an issue with 1st, or maybe it's related to the 2nd gear problem? How much money do you think I'll be into this transmission fix for? Do I need any specialty tools?
    Oh, this is an XJ1100.
    • 8927
    I would touch up all the gear dogs/slots on the countershaft while you are in there. The 5th gear not going in at all could also be a missing pin on the shift drum, fairly common problem. Cost for repairing the transmission is usually pretty low, just some dremel grinding stones and some RTV to put it all back together. If you plan on flipping the bike upside down for the repair, I would remove the oil pan first, you don't really want metal chips from your damaged gears falling back in the engine. Don't forget to relocate the washer to the other side of 2nd gear.
    • GoRacers
      • Aug 2012
      • 81
      • Louisville, Ky.
      I bought a used trans from andreas for cheap. Only "special" tool you need is a torque wrench, torx bits, and a soft mallet if I remember correctly.
      Not a hard job, and there are TONS of walkthroughs and pics on these forums. Just take your time.
      78 E
      • Yard Dogg
        • Mar 2010
        • 884
        • Tri-Cities, Wa
        I had heard about the dremel fix but didn't know what it meant. So all I really have to do is grind the dogs and slots so they pull towards each other huh? I can do that. Will it increase the life of my tranny if done right? What about downshifting? It doesn't seem like it would effect it at all, just curious.
        The tech tips look great, I can't wait to get this thing fixed now.
          • 5073
          I have 3 standards and a special for a parts bike. I have been luck to NEVER have the dreaded transmission problems. I am knocking on wood, real hard.
          • Yard Dogg
            • Mar 2010
            • 884
            • Tri-Cities, Wa
            After reading up on it. I almost think my downshift problem into first could be related to the dogs on 4th gear in combination with whatever is causing it to miss 5th. Does that sound right to those of you who have been in one of these cases?
              • 9981
              I don't suppose it could be that synthetic oil huh?
              2nd gear is most definitly rounded dogs on the 5th gear wheel (engage for 2nd). Just by what your saying I would guess that the star that holds the pins in on the shift drum is broken and the pin for 5th gear has fallen out.
                The 2nd gear skipping like a machine gun is the dreaded dremel fix, not so dreaded once you have done one...or two...or five.
                The not going into 5th is probably not anythign to do with skipping dogs on the gears, but like has been suggested could be a slipped pin on the shift drum.
                The not going down to first, well that could be related to the 5th gear issue.
                • Yard Dogg
                  • Mar 2010
                  • 884
                  • Tri-Cities, Wa
                  I'll see if I can find a pic of that.
                  Oh, I have no idea what kind of oil the PO ran. It hasn't been ridden since 2003 and synthetic wasn't quite so popular just yet. Could be that conventional stuff that did this, hehe.
                    When you pull off your shifter cover, what you're looking for is what I have labelled #1 here.
                    That little washer on the outside has 5 little arms that are easily bent. Those 5 little arms are holding 5 pins in their respective holes. If one of those little tabs (Arms) gets bent, it lets the pins drop out. Might be a bent or hanging pin making 1st gear a pain also. Heck.. may have several of them messed up/bent and not have any actual gear problems at all, it just might not be letting the shift drum get rotated to the right spot. Doubtful it's your whole problem, but likely it's part of it. If one of the pins is missing, it might still be there either in the shifter cover or down at the bottom there where you can see it. Otherwise, you'll have to pull the oil pan to get to it.. which you will have to do anyway if the gears are messed up.
                    • Yard Dogg
                      • Mar 2010
                      • 884
                      • Tri-Cities, Wa
                      I'm definitely gonna check that first. Thanks for the input.
                      • brcree
                        • Mar 2010
                        • 388
                        • S.C.
                        Fyi
                        Yard Dog.....THere is a trans set on Ebay for 100.00. Just lett-en ya know.
                        At this time:
                        1985 Goldwing Innr.
                        1976 cb 750 cafe racer
                        2007 vtx 1300
                        81 sx 1100 s h
                        81 sx 400 special
                        • James England
                          • 3039
                          • North of England
                          I have a 'star' washer if you need one. Free
                            Just 29.95 to send it over the big pond? lol.
                            Nice offer, James. Unless the little arms are axtually broke off, I've seen several just bent back into shape with no ill-effects.
                            • jwhughes3
                              • 2798
                              • Home of the Alamo
                              Hey James, good to hear from you...I was just wondering last night where you had gone off to.
                              John
                              '81 XS1100H - "Enterprise"
