I got some 1157 bulbs and when I put them in the socket it is like they half light up, and when I turn the turn signals on everything flashes but every signal light is extremely dim (indicator bulb, rear, and front turn signal). Even the flasher doesn't click like it usually does. I did try the LED bulb with a battery charger and it does function correctly and it does seem that the appropriate contacts are in the correct place on the base and contact the right correct contact in the socket.
All the other bulbs are LED (only the original tail light and the headlight are the only non-led lights left on my bike) and I am using a 2 prong electronic flasher. This was done with the bike off and the key on, I am going to try with the bike running today if I have time, although I don't know why that would make a difference.
Anyone have some ideas?
For those that participated in my "Making Marker Lights Flash" thread, I have not done anything with that yet so none of that crap to get in the way.
I felt that using the smaller 1157 bulb arrays are just not big or bright enough to provide the amount of visibility I desired, and so that's why I used the larger TRUCK STYLE arrays.
