Popping back through carbs
  • s63921c
    • 31
    • green bay,wi
    Does anyone have any ideas on this issue: I've had a popping back in the carbs at idle since I bought the bike over 10 years ago. Also noted ticking from the valvetrain at idle.I've changed coils,spark plugs,cleaned the carbs extensively and installed new diaphragms,inspected the vacuum advance and wires as noted on the forum,changed plug wires/boots with the proper resistance boots. I also replaced the carb boots after I bought it with Yamaha oem. Nothing seems to change it and it seems lean coming off idle, though at idle the left pipe exhaust appears rich.I have MAC 4 into 2 exhaust on this 1980 midight 1100. I appreciate any ideas-I guess it's gonna be a winter project for me here in Wisconsin. possibly valve clearance issue or sticking valve?
    1980 MIDNIGHT1100 RIDER.
    TRACY
    These engines have a very noisy valve train. They get quieter as the valves wear.
    For the popping, just try opening up your idle mixture screws 1/2 a turn and see if the popping goes away. You can always then it back if nothing changes.
    • WMarshy
      • Apr 2009
      • 2402
      • Mexico NY
      When's the last time you check your valve clearance?
      Sounds like you could benefit from a sync and idle tune.
      '79 XS11 F
      Stock except K&N
      '79 XS11 SF
      Stock, no title.
      '84 Chevy K-10 "Big Blue"
      • s63921c
        • 31
        • green bay,wi
        valve train
        I never have adjusted the valve train and set the sync with carbs off-not by flow-it responded better than ever,but still needs work. My thought is that I didn't want to flow sync the carbs until I stopped the popping back. I have backed off the idle mixture to no avail. I guess I posted this under the wrong header-sorry-not too computer saavy..
        TRACY
        • mlew
          • Jun 2005
          • 226
          • Apex , NC
          Popping back through the carbs is a sign of a lean fuel mixture and/or valves that are out of adjustment and tight. Since you have never checked the valves I would do that first. It is necessary for a smooth engine. After the valves are in spec try richening the idle mixture by turning the mixture screws out 1/4 turn at a time.
          Slow down and enjoy life. If you are in that much of a hurry, you should have left eariler.
          Current rides:
          80 XS1100SG
          82 JX1100
          83 Venture Royale
          86 V-Max
            After you synch the vacuums of the carbs, try coloring clean plugs around idle rpms:
            Use a box fan and just do it in the garage. Warm up the engine first, change to the clean plugs, run the engine at say 1500 rpms for about 5 minutes and shut it off. Check the plugs for color. Too rich? screw in the idle mixture screw a bit...too lean? screw it out just a little. It also might help to check the temperatures of the head pipes. This has worked for me.
            I have a throttle lock that helps the process. I also use a propane torche to clean the standby plugs for a retest.
            • s63921c
              • 31
              • green bay,wi
              valvetrain
              Thanks for the input guys. I'll check the valve clearance next and see where it leads...
              TRACY
              • WMarshy
                • Apr 2009
                • 2402
                • Mexico NY
                One other consideration, check you idle screw tips arnt broken off on the carb bodies...
                '79 XS11 F
                Stock except K&N
                '79 XS11 SF
                Stock, no title.
                • GLoweVA
                  • Jun 2011
                  • 1957
                  • Virginia Beach, VA.
                  Yeah, if those are broken off, then there'd be nothing from the idle circuit and it sure would be a bit leaner.
                  80G (Green paint(PO idea))
                  The Green Monster
                  Got him in '04.
                  bald tire & borrowing parts
                  Scarlet
                  Got her in '11
                  Ready for the twisties!
                  81H (previously CPMaynard's)
                  Hugo
                  Cold weather ride
                    Assuming he still has the stock '80 carbs, those have the the newer blunt tipped idle mix screws that are very hard to break off in comparison the the early model carbs mix screws.
                    • mikubuilder
                      • Jul 2011
                      • 548
                      • Westland, Mich.
                      I don't know if you have mentioned what kind of jetting you have in your carbs....
                      Nick
                      1982 Virago 750 (it's alive!)
                      • s63921c
                        • 31
                        • green bay,wi
                        Jets
                        I had switched to 1 size larger mains before when MAC exhaust and K&n air filter were installed,but it turned out to be too rich. I switched back to the original size (I can't remember off-hand the #) when the carbs were off last year.
                        TRACY
                        • MPittma100
                          • Aug 2011
                          • 2359
                          Popping
                          Popping at or off idle is usually attributed to the pilot circuit. I know you stated that you have cleaned the carbs extensively. Just want to be sure that you cleaned and verify function of the entire pilot circuit. This would be the pilot jet, pilot air jet, and the passage at the butterfly for obstruction. And making sure that the plug for the pilot jet well is reinstalled.
                          MP
                          1981 XS1100H Venturer
                          K&N Air Filter
                          ACCT
                          Custom Paint by Deitz
                          Geezer Rectifier/Regulator
                          Stebel Nautilus Horn
                          EBC Front Rotors
                          Limie Accent Moves On In 2015
                          Mike
                            Any time mine starts popping, I will look and find one of the rubber plugs on the carb nipples missing/torn/cracked.
                              • 3193
                              So Do I. This also makes the assumption that the carbs etc were right in the first place though. Much more likely on your bike Tod, than a possibly less experienced member. Good advice for sure though.
