Tonight I wanted to route the sender wire for my temp guage so I removed the tank. Then I thought I might as well remove my octy and install my inline filters while I was at it. Then I thought I might as well remove the carbs and check my float needles as I was paranoid they were leaking. Also wanted to replace my blots with stainless.
So I checked the needles and seats. All were clean. I checked float heights. Reinstalled the carbs. Installed new fuel line and filters. Started up the bike without the filters, and it wasn;t running the greatest.
I hit the throttle, and noticed fuel spraying out of the #1 carb and only the #1 carb. I have never had this happen before. Has anyone??
I did not have enought time to sync and adjust mixture tonight. Plus I didn't want to do all that work if I'm going to have to pull them again.
Do you think syncing will remedy this? Anyone know the cause?
