As with most thing hes says, i agree with TopCat.
I am an auto mechanic, every cyclinder head I pull goes straight to the machine shop. I have them milled flat, checked for cracks, and cleaned/ They almost Never replace valves that are not Burnt or Bent.
Valves are made to be ground again if needed. You just have to make Certain that after grinding them that you measure the Margin.
Here is a tip.
take valve grindiing compond, but it on the valve & seat. Insert valve into guide. Attach a pice of vacuum lhose to a drill bit, and instet valve stem into vacuum hose. Pull toward you and Slowly rotate the drill. This will remove small pits, scrathed & carbon from the valve & seat. Clean all parts with brake cleaner. Turn head upside down, and SLam the valve into the seat Hard a few times with your index finger. Remove the valve and you should be able to see a small ring on the valve when it contacted the seat. This shows where they meet. That way you can check your margin. I have done this a few times while doing head gasket on jap cars with high mileage. Works like a charm That is my CBMMA advice.
My professinal advice is take the head to a Machine Shop, and let the pros do it. If you take it to an automotive machine shop, the price should be much better than most motorcycle machists. They both do the same job, but the auto shop will win on price. From a machists standpoint, they don't care what the head came off of. All they need is the specs, tolerances, and the valve stem seals. If you do a overhaul you do not need a machinst most likely. if you are going to Rebuild it, you will Need a machinst. Installing ring & lapping valves is NOT a Engine Rebuild.
you may not Need a rebuild though, which is the great part!
Hope this helps you, go visit your machinist.
Here is a tip.
