does it sound like my TCI is bad?
  • mikubuilder
    • Jul 2011
    • 548
    • Westland, Mich.
    OK here is my problem:
    I got my bike running a few weeks ago, but I had some issues with fuel line and petcocks leaking, so I ran it for maybe 5 miles total.
    It was really hard to start, but if I twisted the throttle it warmed up just fine and was running OK(first on choke, then without)
    I also had some issues with oil, then gas coming out of airbox, but I got it all squared away(yes, I did change the oil )
    now I go to start it up again, and it running rough, and no spark on #2 and #3...coils right?
    well, I started to check meticulously, pick up coils(look brand new)
    resistance 720 Ohm by backprobing, and also at the plug to TCI...
    ignition coils 1.5 Ohm on primary, 15k secondary, caps 5.2k each...WTH
    orange and gray wires 11.5V at TCI and at the ignition coil???
    am I on the right track, or did I miss something?
    Nick
    1982 Virago 750 (it's alive!)
    • 8930
    Your timing plate and bolt are missing . Did you tug on those pick up coil wires when checking with the ohm meter? The TCI's rarely go bad.
      Hey there Miku,
      As Phil says, the TCI's rarely go bad, but you CAN have corrosion build up on the plugs/connectors for the TCI, but also the internal solder joints INSIDE The TCI can corrode/break down, and folks have resweated them with success. You'll want to do some other diagnostics to ensure that the signals are being read at the TCI plug/connector and such. Also folks suggest swapping the 2-3 coil with the 1-4 coil, plug wires to other plugs, as well as the Orang/grey wires and then retest. If 2-3 stays with no spark, but 1-4 still gets spark, then you know it isn't the ignition coil, but something else.
      • mikubuilder
        • Jul 2011
        • 548
        • Westland, Mich.
        well, the TCI is not original to the bike, I bought of fleabay ,so it was always a questionable one...
        I guess I could swap coils and plugs, to double check, but according to manual it would be TCI as I did all the checks to ignition coils as well as pick up coils
        I cleaned all connectors and used graphite grease that I use in my welding rotating connectors(Tweeco but I don't remember part number), and all connections check out fine, both for resistance and voltage...
        I sent money to Lee Dutcher for a known working TCI, so I guess until I get it I can try all the other tricks
        Nick
        • Rasputin
          • 3193
          • Lacombe, Alberta, Canada
          Do you have access to a fax machine right now?
          Color machine is better.
          2-79 XS1100 SF
          2-78 XS1100 E Best bike Ever
          • mikubuilder
            • Jul 2011
            • 548
            • Westland, Mich.
            couple more things that I have noticed:
            with ignition on, and not running orange and gray wires at TCI both have about 11.5 V, but when I start the engine voltage drops to 3V on orange and 5.5V on gray...does that seam normal? I thought it should drop to 9 V or something like that....
            Nick
            • Rasputin
              • 3193
              It can be normal if you are testing it correctly. You have to have the older style swinging needle tester to get the right results. I have the info here but no way other than a fax to get it to you anytime soon. If you have a fax number PM it to me and i will send it.
              2-79 XS1100 SF
              • Rasputin
                • 3193
                Correction... My wife just informed me that the Fax is broken. Sorry. I will try to copy and paste or something in the meantime.
                2-79 XS1100 SF
                • mikubuilder
                  • Jul 2011
                  • 548
                  • Westland, Mich.
                  LOL no fax here, I have one at work, will PM you tomorrow...can you paraphrase? and no, I don't have an analog meter
                  Nick
                  • Rasputin
                    • 3193
                    This is stolen, borrowed or even plagarized from Randy's site before it went away. It does require an analog meter as the dimm's do not show the swing of the needle that is required to test it. maybe you can borrow one from someone real old who may still have one...lol.
                    Using a voltmeter set on 12VDC, connect the positive meter lead to the Orange or Grey coil lead at the TCI. Connect the negative meter lead to the black (negative) lead at the TCI. Turn on the ignition. Voltage should come right up to about 10 - 11VDC. Crank the ignition and observe the meter. Look for a wide voltage swing during cranking. A strong swing indicates that the pickups and TCI are working OK and your trouble is between the TCI and the plugs. Possibly a bad ballast resistor, bad coil, bad plug cap or just corroded connections. Repeat this test for both Orange and Grey coil leads.
                    2-79 XS1100 SF
                    • ViperRon
                      • Feb 2011
                      • 1062
                      • Woodstock, VA
                      As TC said previously swap coils and plugs before you go too far on the TCI failure road. Expecially if you have Champion plugs. You had flooding issues at first and even if they were new I have had fuel cold foul plugs. They can get real intermittant also. Testing with a meter is good but since you have 2 nearly complete ignition systems swapping is a tried and true method.
                      Rodan
                      1980 G Silverbird
                      1198 Overbore kit
                      Grizzly 660 ACCT
                      Barnett Clutch Springs
                      R1 Clutch Fiber Plates
                      122.5 Main Jets
                      ACCT Mod
                      Mac 4-2 Flare Tips
                      Antivibe Bar ends
                      Rear trunk add-on
                        It was asked by someone but never answered. Did you tug and pull on the pickup coil wires? You need to.
                        • mikubuilder
                          • Jul 2011
                          • 548
                          • Westland, Mich.
                          I did tug on all pickup coil wires with no avail...all ignition wires were trimmed and they all check out with multimeter, as well as all caps( I even switched them around)
                          one more thing I noticed that might help:
                          when I get bike running on 2 cylinders(full choke), and rest a connected spark plug on a engine, there is no spark....but when I hit a kill switch, there is one spark at the end....what would that mean?
                          Nick
                          • DAVINCI
                            • Jan 2011
                            • 1048
                            • Cedar Mountain, NC
                            Good one, rasputin!
                            BTW, if you don't have an analog meter, you can use an incandescent test light instead.
                            Yup, sounds to me like you need to re-sweat those solder joints for the 2-3 coils, INSIDE the TCI.
                            BTW, this is RANDY, under a different name. Long story. Here are the pins to re-solder:
                            pay particular attention to the two pins on the left, bottom one is for coil 2-3 (GRAY), the top one is for coil 1-4 (ORANGE).
                            • mikubuilder
                              • Jul 2011
                              • 548
                              • Westland, Mich.
                              thanks Randy, I know your new nick and was hoping you would chime in, as you're most experienced with our black boxes...will give it a shot
                              Nick
