Brakes... again
  • JScro
    • Feb 2012
    • 70
    • Austin, Tx.
    Brakes... again
    So the last piece of my brake rebuild was adding stainless lines to the front. The ones I ordered originally were the wrong size. This weekend, I did a lot of work to the bike including installing the new brake lines.
    Everything was fine until yesterday coming home from work. Squeezing the lever when I got home, I noticed fluid coming out of my left front caliper.
    Taking it apart, it's really clean. There is some pitting in the caliper itself though. I'm assuming it was fine before due to the old lines being really bad, and it not building up much pressure. They've been fine before the new stainless lines for the last 3-4 months.
    So, is there any good way to really tell if the caliper is truly bad? My thought is to reseat the piston, hook the one caliper up to the master cylinder and just start squeezing to see if fluid starts coming out.
    If it's f'd is there really any fix? Found one off a wrecked bike on eBay for cheap and ordered it just in case.
  • James England
    • 3039
    • North of England
    So, you rebuilt the caliper with a seal kit, right? But used the original piston, complete with pitting. Usually the pitting is not in the area that slides inside the seal. But, now you've fitted braided lines, you have a fluid leak at the piston. Is that it? If so, it's probably the seal you used having some crud on iot. Is it in correctly? Did you throughly clean the cylinder after removing the piston and old seal? Exactly where is the fluid leaking from?....'Caliper' is a broad term....
    • WMarshy
      • Apr 2009
      • 2402
      • Mexico NY
      Is there any chance you pinched the o-ring on the piston when you assembled it? If you end up taking it out again I recommend hitting the bore with some fine sandpaper to clean up any corrosion and junk that might be stuck in there. I dont see any way around taking it apart again and inspecting that o-ring...
      '79 XS11 F
      Stock except K&N
      '79 XS11 SF
      Stock, no title.
      '84 Chevy K-10 "Big Blue"
      • JScro
        • Feb 2012
        • 70
        • Austin, Tx.
        I didn't reuse anything, it's a new seal and piston. The fluid leak definitely seems like it's coming from the seal. Taking it apart again this evening, it really looks fine besides some really light scratches inside the bore itself.
        I'll try some fine sandpaper and put it all back together and see what happens.
        My wife is laughing at me, I think this is the 4th time I've had my front brakes apart now.
        • JScro
          • Feb 2012
          • 70
          • Austin, Tx.
          I took the caliper apart again last night, and I did find one section of the seal seat in the bore that looked like it still had a bit of crap in it. Cleaned it out, put it all back together, and now I'm hoping for the best.
          At least I can tear down/rebuild my calipers and bleed my brakes in a matter of minutes now.
          • mjpxs11sh
            • Jan 2011
            • 299
            • N/E, Illinois
            _
            theres nothing more aggrivating when ur wife thinks ur an idiot. thats why i dont have 1. haha haha i can laugh at myself!
            it sounds like u found the culprit. practice sometimes makes perfect, but not always. good luck!
            Max
            81 XS1100SH Black Beast Mutt
            Kerker 4/1
            stock carbs and air box.
            78 headlite, handle bars,
            1 set of ea-160/85mph guages,
            crash bars, cruise control
            Other 2 Wheelers
            78 XS1100E jet kit, Kerker 4/1, air pods, jet kit-RIP
            94 CBR1000F jet kit,Two Bros pipe, K&N Filter
            • JScro
              • Feb 2012
              • 70
              • Austin, Tx.
              LOL.
              I actually think my wife probably believes I sabotage my bike just so I can keep working on it.
              • CaptonZap
                • Jun 2010
                • 1748
                • Denver
                Originally posted by JScro
                LOL.
                Tell her that she should be thankful that you are working on it, and not hanging out with the Harley riders at the local bar. CZ
