i was wondering if the hoses on the oil cooler could be replaced with newer braided hoses. there is nothing wrong with mine but i just was wondering so as to clean up the front of the bike with new shiney hoses.
oil cooler
Tags: None
Why don't you buy a hose kit? My nephew installed stainless steel hose dressings under the hood of his car, they look good. Cheaper too. Summit would have them for sure."The Hooligan" XJ1100, Virago Gauge Pods, Screaming Eagle Mufflers, K&N Filter, hand made rear fender, side covers, and solo seat, round bar conversion, small headlight, tail light, and cat eye turn signals, chip fuses, rewired the right way.
Pics: http://s1236.photobucket.com/user/ya...?sort=6&page=1 -
Thought you were going for a "neglected" look?
JohnJohn is in an anonymous city with an Alamo (N29.519227,W-98.678980)
'81 XS1100H - "Enterprise"
"Not all treasure is silver and gold"Comment
Yes, you can just buy some braided hose, but just remember that when you cut it, that braiding gets frayed, so put your hose clamp over the line first, cut it the length you need, then slip the hose clamp over the cut/frayed part to hold it from coming apart any more. I found that using a Dremmel tool and a cutting wheel caused the least amount of movement to the wires while cutting, but other ways will work.
I then found a clamp from some Harley farkle place (Looked and can't remember now.. sorry) to run the line against the frame.
I just got my line from a local place that made hydraulic lines.Last edited by trbig; 09-17-2012, 04:57 AM.Try your hardest to be the kind of person your dog thinks you are.
Do they make an AN fitting to fit in the oil cooler? Those fittings will usually enclose the frayed end of the braided line. But they are quite expensive.Life is what happens while your planning everything else!
78 XS750Comment
i have seen those on some harleys and my friend has them on his chopper, i do like how it keeps them tight to the frame.Yes, you can just buy some braided hose, but just remember that when you cut it, that braiding gets frayed, so put your hose clamp over the line first, cut it the length you need, then slip the hose clamp over the cut/frayed part to hold it from coming apart any more. I found that using a Dremmel tool and a cutting wheel caused the least amount of movement to the wires while cutting, but other ways will work.
I just got my line from a local place that made hydraulic lines.Comment
New Hoses
If you wanted to stay with the OE style hoses, there is a braided nylon hose that is made in black that can be used with AN fittings or clamps.
MP1981 XS1100H Venturer
K&N Air Filter
ACCT
Custom Paint by Deitz
Geezer Rectifier/Regulator
Stebel Nautilus Horn
EBC Front Rotors
Limie Accent Moves On In 2015
MikeComment
I just went to the local Home Depot and got some brass fittings with the notched nipples for putting a hose on. Threaded right into the cooler with some teflon tape.Try your hardest to be the kind of person your dog thinks you are.
Understood that was an option Tod, as a fellow cheapazz I am sure I would do the same on my bike. Just offering up an option for a more finished product for the less careful or skilled at cutting braided line.Life is what happens while your planning everything else!
78 XS750Comment
