Last Friday, I finally got around to doing my valve shims and WOW, I'm surprised by how much more power and response I have now.
Every one of my 8 shims needed to go down at least one size some 2 sizes.
I started the day tearing apart my SG to get the shims out of it to use.
Then I moved on to my G. Before pulling the cams out, I measured them all.
CatatonicBug had sent me a 255 because I knew I needed one, but as it turned out, I needed 2 more.
So I called up the closest Yama dealer and he said sure, we'll trade them out.
Took 2 of my 295's down there and BAM, two 255's in my hand. Turns out, they were just a hair too big.
Call the BMW dealer and he had 2 ($8) a piece!
So, got those in and put cams back in and checked all my clearances, and they are all at the top spec or just a hair over, so they should be good to go for many more years.
While I had the fairing off and enough hours left in the day, I decided to finally change out the front upper motor mounts to get rid of that nasty vibration that make my right hand go numb after 30 mins of riding.
It took a breaker bar to loosen the bolts, but they came out okay.
Here's a pic:
So my new ones didn't come with the metal insert sleeve. No problem, I'll just pull the old ones out.
Yeah, right. Those suckers were vulcanized to the rubber. It took me 3 hours to get those 2 out and cleaned up enough to use.
After all that, I got it all back together and wouldn't you know it, My 'Vibration' has gotten worse.
I guess those polyurathane bushings transmit the vibration a little more than the rubber stock ones do. Add to that the fact the my valves are a little more open now which probably adds to the engine vibes too.
Anyway, I'm glad I did the valves and the mounts, they needed it.
I'll take the trade off of a little more vibration with the increase in power and performance now.
Here's a pic:
