Today, I was heading to lunch and going 75-80 on the interstate. After a few minutes of going those speeds it started slowing down and I really couldnt keep it above 70. It would surge in speed for half a second and kept doing that...I made it to lunch. On the way back pretty much the same thing happened. It accelerates nicely and if I sustain lower speeds it seems fine. I do have a hard time getting it started after it has sat for a few days. I have to use starting fluid but after the initial start it works great for the rest of the day.
Also when I got the bike in 2010 the carbs needed to be cleaned. I did as much as I could but I probably need to do an acid bath or something. It would probably fix the issue..I assume its the carb. Anyway Im just trying to give you as much as info as possible. Thanks for the help and if I think of anything else I will add it...
I have a 1980 XS11 Special
Okay, you have a Special, do you still have the OCTYPUS vac. controlled valve...that funny thing with all of the fuel hoses coming out of it sitting on the top of the #2 carb body? If so...then the control valve/vac valve/diaphragm may be damaged or stuck so it's not allowing the proper fuel flow....and at higher sustained speeds the carbs are running LOW. OR...it could be just the vac. hose from it to the intake boot that has gotten cracked or such so that you're not getting enough vac. to keep the valve open enough? Or...your gas cap vent may be partly clogged so that it creates a vac. lock and prevents the fuel from flowing.
