Right turn signal not working correctly.
  • ntrthamatrix
    • Jul 2010
    • 4
    So I have a weird issue going on. My left turn signal works correctly. You activate it and it auto cancels after the turn etc. When it comes to my right turn signal I cant get it to turn on except once or twice in a 1000 miles. I hit the switch and nothing will happen. I have had it turn on after turning right but I cant reproduce this. I have opened the controller and made sure it was clean and it looks like everything is making a connection. Not sure where to go now..thanks for the help.
    You need to chase the grounds as well as power side on each right side turn signal itself. You may have a loose connection. Does one bulb light and the other not? Otherwise, it could be you need to disassemble the switch and see what is going on inside. As tight as that is in there a wire connection could come loose and still look intact till you open it up.
    • conquest87tsi
      • Jun 2012
      • 190
      • Jackson, Minn.
      No Blinky
      I would remove the turn signal switch from the left handle bar. What happens is the solder securing the wires to the switch's contacts breaks away due to viration, age, whatever. I had this problem on both of my XSs. Amusingly it was also my right turn signal that wasn't working. I removed the switch and completely disassembled it and found that both left and right wires where disconnected, but the left side must have been just touching. All I did was resolder the wire to the contacts. Like I said you will have to remove all the components to do this.
      1979 XS1100 SF
      1979 XS750 SF
      Previous Rides:
      1981 KZ650CSR
      2006 VTX 1300C
      1986 Radian 600
        Have you removed the lenses from both lights? That's the first place you'll get corrosion. Clean it all up. Grounds clean and secure? Check the switch contacts for corrosion. I wouldn't suspect a broken wire unless you have been messing with it or your bike runs on two cylinders and vibrates like an old Triumph. If it's broken, you'll find it when you go in there to clean it up.
        • Yard Dogg
          • Mar 2010
          • 884
          • Tri-Cities, Wa
          Yup, check your bulb sockets and the soldered connections in the switch. If you have to solder the wires in the switch onto the contact nodes, do not spend to long on it with the soldering gun, cause it will melt the plastic holding the contact node and you'll have to replace the switch. Heat just long enough to get the wire back on the contact node then stop.
            What he said. If it comes to that, use a 10 watt soldering iron.
            • GLoweVA
              • Jun 2011
              • 1957
              • Virginia Beach, VA.
              I'm kinda having the same issue with my G. The right signals blink erratically while the left one works just fine. I haven't had a chance to troubleshoot further, but my hazards also blink crazy too. I'm guessing my issue is either with the handlebar switch or downstream towards the right side bulbs.
              2 years ago, I had my switch apart for a resolder job and that was a PIA.
              I hope I don't have to do that again.
              Once I figure it out, I'll post up here what I found for all to learn from.
              80G (Green paint(PO idea))
              The Green Monster
              Got him in '04.
              bald tire & borrowing parts
              Scarlet
              Got her in '11
              Ready for the twisties!
              81H (previously CPMaynard's)
              Hugo
              Cold weather ride
              • ntrthamatrix
                • Jul 2010
                • 4
                Thanks
                Thanks for all the info so far. I will give them a try and let you know..
                  Originally posted by ntrthamatrix
                  So I have a weird issue going on. My left turn signal works correctly. You activate it and it auto cancels after the turn etc. When it comes to my right turn signal I cant get it to turn on except once or twice in a 1000 miles. - - -
                  Hi 'trix,
                  did the bike always do this or is it a new thing?
                  If you used to see both sides working you got the right bulbs in.
                  If one side works properly it ain't the flasher or the canceller.
                  Rig a jumper wire from the T/W wire to the G wire to bypass the indicator switch.
                  If the rightside signals work the problem is in the indicator switch.
                  • Tat2demon
                    • Jun 2012
                    • 718
                    • Sioux Falls, South Dakota
                    Exact same thing happened to me a couple weeks ago.
                    Nate
                    78 XS11 "Matilda" 2H7 000364
                    K+N Air Filter
                    88 Voyager XII
                    81 XJ650 Maxim
                    • conquest87tsi
                      • Jun 2012
                      • 190
                      • Jackson, Minn.
                      Hey Tat2Demon,
                      You have a pretty bug XS following over that way? Saw an add on Craigslist a while back about someone wanting to start up a group.
                      1979 XS1100 SF
                      1979 XS750 SF
                      Previous Rides:
                      1981 KZ650CSR
                      2006 VTX 1300C
                      1986 Radian 600
                      • GLoweVA
                        • Jun 2011
                        • 1957
                        Fixed my issue
                        So I found out why my right side lights were flickering intermittently/sporadic.
                        It turns out the the wire connector going to the right saddlebag was grounding out on the bag frame and as I went over bumps in the road it would clear, so it would flash a little until the next bump.
                        It suprized me that it wasn't enough current flow to blow the fuse. I guess the stock flasher has enough internal resistance to keep it low enough, or the stock flasher kept it from flashing on the right because the load was 'off' (ie. not 57W)
                        Either way, I now know something new about these signals,
                        With a stock flasher, if one bulb is out/open, then the flasher 'sticks' 'on' on that side, but if you've got a 'short' then the flasher won't flash at all on the side with the 'short'.
                        The Green Monster
                        Got him in '04.
                        Scarlet
                        Got her in '11
                        Hugo
                        Cold weather ride
