engine mount bolts
  • silver_ride
    • Aug 2011
    • 41
    • Minneapolis, MN
    engine mount bolts
    I just snapped 2 ratchet drives trying to take out the engine mount bolts to install my highway pegs..how the hell do i get them loose?! Preferably without having to buy a blow torch
    80 XS1100G
    Use a breaker bar!
    • silver_ride
      • Aug 2011
      • 41
      • Minneapolis, MN
      Whats a breaker bar? U mean a cheater pipe to lengthen the ratchet? That'll still break the tool..
      80 XS1100G
      • WMarshy
        • Apr 2009
        • 2402
        • Mexico NY
        Breaker bar dosent have a ratchet and is typically longer than a normal ratchet. I have a 1/2" drive breaker with a 30" handle. I havent found anything I couldnt spin off. Google breaker bar.
        '79 XS11 F
        Stock except K&N
        '79 XS11 SF
        Stock, no title.
        '84 Chevy K-10 "Big Blue"
          Soak the bolt threads with PB Blaster penetrating oil and use a 1/2" drive breaker bar. A breaker bar doesn't ratchet, it just has a square for the socket on a long handle. If possible, try to loosen the nut side instead of the bolt head, the bolt may be frozen in it's bushing, you can hammer that out after the nut is off.
          • jwhughes3
            • 2798
            • Home of the Alamo
            Use Craftsman. If you break it they replace it.
            But a breaker bar is better.
            John
            '81 XS1100H - "Enterprise"
              • silver_ride
                • Aug 2011
                • 41
                • Minneapolis, MN
                Excellent thanks dudes...yeah that 1/4" drive ratchet seems to be the achilles heel! Hopefully i can find a breaker bar in town here for cheap, its starting to get pretty spendy just to have the the luxury of putting my feet up
                80 XS1100G
                  After trying to get Special Eds engine out, I can give a hint or two.
                  1. Take the NUT off(inside the frame/engine) and THEN try to remove the bolt.
                  2. Cut the head off the bolt, drive the bolt in past the fame, cut the bolt on the inside of the frame, drive it back again and jack up the front of the engine to remove the mounts. You can THEN try and remove whats left of the bolt from the mount(good luck!). Because of the steel sleeve inside of the mount, the bolt WILL rust to it.
                  I hope the bars come with the longer bolts you will need!
                  • silver_ride
                    • Aug 2011
                    • 41
                    • Minneapolis, MN
                    Longer bolts eh? I 'm not gonna mess with it anymore then! Anyone want a set of engine guards w pegs? $30 plus shipping theres no way im dealing w any more of this BS just to put my feet up
                    80 XS1100G
                      Which guards have you got? If it's the 3 point set that sold on ebay the other day I'll take em.
                      Got a pic?
                      • silver_ride
                        • Aug 2011
                        • 41
                        • Minneapolis, MN
                        3 pointers, yes i have a pic, i'll PM you shortly. everyone else, thanks for your help
                        80 XS1100G
                        • jwhughes3
                          • 2798
                          • Home of the Alamo
                          Got a pic?
                          Greg finally gets the 3-pointers!
                          John
                          • WMarshy
                            • Apr 2009
                            • 2402
                            • Mexico NY
                            I call seconds. Let me know if Greg misses the 3 pointer, I'm interested.
                            '79 XS11 F
                            Stock except K&N
                            '79 XS11 SF
                            Stock, no title.
                            • ManagerMike
                              • Mar 2010
                              • 445
                              • S.E. Michigan
                              Putting your feet up is pretty nice
                              '78 E "Stormbringer"
