where can i get set of vacuum gauges to so i can sync my carbs? do i really need 4 gauges or can i set up 2 carbs at a time?
Carbs syncronizeing
If you have the money for it I suggest getting the carbtune. Very easy, no messing around with celebrating gauges or anything like that. Best motorcycle tool investment in my mind.
http://www.carbtune.com/
If you really want vac gauges, most by them off ebay.
4 gauge setup makes it easier and faster, and just gives better accuracy. Some people pull it off with just a single gauge though.Nathan
Originally posted by natemoen View PostIf you have the money for it I suggest getting the carbtune. Very easy, no messing around with celebrating gauges or anything like that. Best motorcycle tool investment in my mind.
4 gauge setup makes it easier and faster, and just gives better accuracy. Some people pull it off with just a single gauge though.1980 Yamaha XS1100LG Midnight Special
thats pretty cheap i can get the carbtune pro 4-coloumn and pouch for about $84 CAD to my door thats not bad. thanks alot i will most likely buy one of these. i do alot of snowmobile engines as well i can use this for everything1980 Yamaha XS1100LG Midnight Special
For years I used the plenum setup in the tech tips. Only I could never find an aquarium valve that worked for crap, so I just moved the tube from one carb to another back and forth till I got consistant readings. I also used my Mity-vac as the vacuum gage.
It worked pretty well, got good results, and the bike ran and sounded good. Then I got a little spendy and decided to pony up for the carbtune setup. I can now tell you that it does cut the time in half or less. I do hear an improvement in the accuracy of the synch. Not sure I would say the performance of the bike is noticably different, except at idle. But I do hear it idle smoother.Life is what happens while your planning everything else!
Originally posted by captjanes View Postthats pretty cheap i can get the carbtune pro 4-coloumn and pouch for about $84 CAD to my door thats not bad. thanks alot i will most likely buy one of these. i do alot of snowmobile engines as well i can use this for everythingI do agree though, it's a very nice system. Simple, compact and portable. Definitely get the case for it though.
This is the set of gauges I got except they all came on one mount. They work pretty well.Nate
78 XS11 "Matilda" 2H7 000364
K+N Air Filter
88 Voyager XII
81 XJ650 Maxim
These need new hoses but the price is right..... http://www.ebay.com/itm/Carburetor-S...913187&vxp=mtrGreg
Originally posted by captjanes View Postthats pretty cheap i can get the carbtune pro 4-coloumn and pouch for about $84 CAD to my door thats not bad. thanks alot i will most likely buy one of these. i do alot of snowmobile engines as well i can use this for everything2-79 XS1100 SF
2-78 XS1100 E Best bike Ever
I use your run of the mill JC Craply Vacuum gauge set. About 40 bucks sent to the door. (At least it did a few years ago) Can be used on any application that needs vacuum gauges, from 2-4 carbs, all carbed bikes, multi carbed cars, etc....Can even be used as a drunkards game of "Who has better lung power"S.R.Czekus
1-big XS patch
1-small XS/XJ patch
1-XS/XJ owners pin.
Just do it !!!!!
Originally posted by Czekus21 View PostI use your run of the mill JC Craply Vacuum gauge set. About 40 bucks sent to the door. (At least it did a few years ago) Can be used on any application that needs vacuum gauges, from 2-4 carbs, all carbed bikes, multi carbed cars, etc....Can even be used as a drunkards game of "Who has better lung power"
I have a set just like I posted the link to. I synced my carbs with a set of carbtunes and it ran like crap until I resynced with my guages.
I've never seen a Colortune work on these bikes, not with stock coils anyway. All I've ever seen it do is cause a misfire on the cylinder it's hooked to.
I've always used the vacuum guages to set my idle mixture.Greg
