MSD spark plug wire
  • le_bucheron
    • Sep 2012
    • 45
    • Montreal, Quebec, Canada
    MSD spark plug wire
    I tried the search button and I have not found an answer to my question. I have a xj1100 1983 canadian. I want to make an upgrade with dyna 3 ohm coil and I would like use some MSD wires. What are the specs I need to follow? Is that they are good for my application:
    http://www.msdignition.com/product.a...639&terms=5553
    Have you any suggestions? I want the black wires and the plugs MSD not too expensive
    Does anyone can tell me what is this coil?
    83 XJ1100
    06 FZ1 naked abarth
    I wouldst get those with since they come with straight plug boots. You are going to want 2 short 90 degree plug boots and 2 long reach 120 degree boots. Any solid core plug wire will work. Don't get the fancy carbon core or anything else like that. The core Is to brittle to stand up to the vibrations of the free hanging wires on a bike. For the coils get Dynatek DC-1 coils. They are pretty close to bolt on.
      Not sure about the MSD coils your planning to use. The coils I have seen require 7 MM wire to fit into the coils. I also found the Carbon Fibre wires did not conduct well for me. I finally found some 7 MM copper core plug wire on Z1 Enteprises, other sites carry it to.
      • le_bucheron
        • Sep 2012
        • 45
        Thanks for info!
        Does anyone know what coils used on the photo of the bobber?
        83 XJ1100
        06 FZ1 naked abarth
        • petejw
          • 2269
          • sydney australia
          Originally posted by le_bucheron
          Thanks for info!
          ull need a closer pic,
          is there anything written on it?
          pete
          new owner of
          08 gen2 hayabusa
          former owner
          1981 xs1100 RH (aus) (5N5)
          zrx carbs
          18mm float height
          145 main jets
          38 pilots
          • le_bucheron
            • Sep 2012
            • 45
            @petejw: no It's the only one photo I had...
            Another question: The wire package from dyna DW-200 Does it come with 8 spark plug boot?
            83 XJ1100
            06 FZ1 naked abarth
