Almost sorted!!
  • Camulus
    • Apr 2012
    • 9
    • Huntingdon, England
    Almost sorted!!
    Well, nearly there!
    After the recent problems it's just about sorted, original carbs had a leaking diaphragm, holed float and on close inspection the pilot holes welded and re-drilled - badly!
    The vacuum advance was knackered and allowing too much air into one cylinder.
    Had bought a replacement set of carbs to do up over winter but these are now on in place of the originals and working fine.
    So far I have bought 3 so called working advance/retard units at £50 a pop and none of them work so the pipe is just clamped off.
    But at least it's working, and a damn sight better than when I first got it - it actually goes 90% like an 1100 should now!!
  • MPittma100
    • Aug 2011
    • 2359
    There is one on Ebay
    I see one on ebay. (search: Yamaha XS1100 vacuum advance). Maybe before you buy another, have the seller check it with a vauuum gun or other source. You still have the mechanical advance from the unit and some is a lot better than none.
    I have no spares, but maybe someone on the site does.
    MP
    1981 XS1100H Venturer
    K&N Air Filter
    ACCT
    Custom Paint by Deitz
    Geezer Rectifier/Regulator
    Stebel Nautilus Horn
    EBC Front Rotors
    Limie Accent Moves On In 2015
    Mike
