Question on geometry of bike
  • XS1100 Newbie
    • Jun 2009
    • 1106
    • Battle Ground, Washington
    I am thinking of maybe changing my MNS over to Standard forks, brakes, and triple tree. Is there any difference in the rake between the Special and the Standard? I ran this bike with Standard triple tree, and Special forks when i first got it, and it seemed to handle ok. I have the forks, and triple tree, just need calipers, and hoses.
    1980 XS1100LG Midnight
    1991 Honda CBR1000F Hurricane
    A cold beer and another one!
    The triple trees were modified between the Standard setup and the Special setup to keep the same rake and trail. As long as you get both together, there is no change to the steering geometry.
    • CatatonicBug
      • 6117
      • Clinton, UT
      I'm just curious - Why would you want to do this?
      • XS1100 Newbie
        • Jun 2009
        • 1106
        Cause i hate those frigging Special brakes. At least the Standard has real mountings the them. I just think that they may function better. I got to thinking though, i may need a fender as well, or do i?
          I totally agree on the Special brake system. CBug has the 81 MNS model which has the XJ brakes, different setup than the rest of the Specials. That goofy mounting bolt and the sloped pads make it a PITA to get setup correctly, and limits the upgrade mods substantially.
          Yes, you will also need the fender. They are a different mounting location which will not work with the wheel location.
            You'll have to do a few other mods too... the headlight ears are longer on the Special (the trees are further apart), you'll need to trim about 5/8" off one end or the other. You'll have to fab a lower headlight adjuster bracket or mod what you have. I did this swap, look here... http://www.xs11.com/forum/showthread...ht=Yawn&page=2. The brakes hoses are the same, you don't need to change those.
            I'm not a fan of the special brakes either....
              • 8061
              You can buy a fender from a XS650 Special. It will b e perfect match. Y ok can even buy a new fender from Mike's XS.
              • XS1100 Newbie
                • Jun 2009
                • 1106
                Thanks for the info guys.
