I'm putting the forks back together and the manual says "Apply a light coat of lithium soap base grease to the O-rings in the air joint bracket." I have a spray can of Valvoline "Pyroil White Lithium Grease," is this the right stuff? If not what am I looking for? Thanks.
Fork Reassembly
just use whatever fork oil ur using
and smear a bit of that on the seals,
u'll be fine.pete
new owner of
08 gen2 hayabusa
former owner
1981 xs1100 RH (aus) (5N5)
zrx carbs
18mm float height
145 main jets
38 pilots
[url]http://www.youtube.com/watch?v=3pA8dwxmAVA&feature=mfu_in_order&list=UL[/url] -
I have not pre-lubed my seals before assembly, not been a problem to date.Life is what happens while your planning everything else!
78 XS750Comment
