Relay help.
  • Filter
  • Relay help.
    I have 2 relays here from the wiring harness on my XJ and need to decide which one to use for a headlight relay.
    1st relay says: 4h7-? Omron 09y1d9 Second relay says: 4u8-00 Omron 28y1d9
    Which one should I use? I also can't remember how to replace a diode. I know I can get them at radio shack, but I'm not sure which one it is, and which direction it needs to be. I can see where in the wiring harness it should go, but maybe you should tell me just to be sure.
  • #2
    You don't need a relay; the headlight power is ran through the start button and disconnected when the button is pressed...
    • #3
      Isn't that what the relay does? I see where the R/Y wire leaves the fuse and passes through the starter switch, then comes out into L/B. After that it runs into the reserve lighting unit. The reserve lighting unit must be the function for the headlight relay also then huh? I removed the reserve lighting unit, so if I want this function back I will have to add a relay right?
      Right now, I've run my R/Y wire from the fuse to the beam selector switch from there it goes to high or low. So the headlight is wired directly to the ignition switch.
      • #4
        The XJ doesn't have a headlight relay; the RLU is for switching from high beam to low (or vice-versa) if one burns out.
        Whether or not one of the starting circuit relays would work as a headlight relay (connected like a '80-81 relay) is hard to say as the coil voltage may not be right.
        • #5
          One relay was for the kickstand, the other I can't remember. The starter relay is the round solenoid right? Those are the only 2 relays I see in the diagram, yet I seem to have 2 here. I only have 1 pigtail that would match a relay in the wire pile. I may have had an extra solenoid that came with the bike though, so don't worry. All Is still right so far
          • #6
            You know what? I think one of them may be the starting circuit cutoff. What do you think?
            • #7
              Yes, one is the cutoff relay; the other one is the sidestand relay. These are interlocked so you can't start the motor unless the bike is in neutral or the clutch is pulled and/or if the sidestand is up.
              I wouldn't try using either of these for a headlight relay as it's unlikely that they're rated for continuous duty or the amps needed. If you really want to add a headlight relay, get one off a '80-81 XS or a generic Bosch headlight relay and use one of those. If you leave the headlight power connected through the start switch, you don't need a relay; the headlight will go off when starting the motor.
              • #8
                I'll just add a handlebar switch so I can turn off the headlight when I'm wrenching on things. More reliable that way, kind of what I'm after anyway. Thanks for your help
