Shocks
  • Keithh
    • Jun 2011
    • 56
    • Chesapeake, VA.
    Shocks
    Greetings all,
    Now that the bike seems to be starting with regularity (don't speak too loud) I'm looking at the next upgrade - just can't stop tinkering with it!
    I know the original shocks leave a lot to be desired. Just wondering what folks have had success with in upgrading. Looking to get off E-Bay - not new off the shelf. I have financial limits!
    Also, being somewhat vertically challenged, I was thinking about going with a 12 inch verses 12.5 inch length. Anyone has experience with that - does it help much? Does it affect handling to any significant degree?
    Any thoughts appreciated!
    Keith
    Keith
    Current:
    1979 XS11F - "Sigmund"
    1975 Triumph T150V - "Ralph"
    1975 Honda CB125S - "Blue" - built for my daughter to learn on.
    1983 Kawasaki GPZ 550 - yet another bike that needs me! It followed me home...
    Previous:
    1975 Norton Commando
    1969 Triumph Tiger 650
    2002 Yamaha YZ250F
    • 9980
    There are 2 things to consider with shortened shocks..
    1) lowering the ride height will decrease your clearance when leaning in turns. It'll be easier to drag a peg.
    2) There is a greater possibility of the rear wheel bottoming out in the rear fender. There are things inside that rear fender you don't want the tire rubbing on. I'm not sure what all is up in astandard fender but I have seen the plasic inner fender and TCI melted from tire rub on specials after shorter shocks were installed.
    • 650mark
      • Jul 2012
      • 307
      • Mesa, Az.
      shocks
      the shocks on my '80 special are 1/2" shorter than stock. works performance units, work great but for the p.o. they were hellaciously expensive($500). they make the bike just lower enough so that when on the sidestand the bike is sitting almost verticle. in other words it doesn't lean to the left very much so i must be carefull when i park to make sure the bars are all the way to the left so the bike can't fall over to the right side. so i use the centerstand and no problem.
        A couple options that are improvements for you would be the SHOWA shocks off a Honda, and the XJ air shocks. I put a set of XJ shocks on my SH and notice a definite improvement. They are also more adjustable by changing the air pressure.
        • Yard Dogg
          • Mar 2010
          • 884
          • Tri-Cities, Wa
          Have you considered shaving your seat? There is more than enough foam on these things to do that. I put a solo seat on my old Midnight and the bike was shorter and way more comfortable because I was laid back on it. I hate the way the stock seat makes me sit straight up, it tires me out. After that you can add yourself some highway pegs and you'll be riding in a recliner.
            • 9980
            OK, 3 things. I hadn't thought of how it would sit on the sidestand.
            • Keithh
              • Jun 2011
              • 56
              • Chesapeake, VA.
              Thanks for the input - some things I hadn't considered, but now will be part of the equation!
              Keith
              Current:
              Previous:
              2002 Yamaha YZ250F
              • tweeleft
                • May 2009
                • 110
                • Bend Oregon
                Hello. I installed shocks off a. 1100 virago. They are one inch shorter. Having a 29 inch inseam I sit almost flat footed. Haven't rubbed the rear tires or pegs yet and she handles a little better. Good luck.
                Keep the shiny side up
                1979 XS1100SF
                Mac 4-1
                Drilled airbox Uni filter
                Vmax bars
                Virago 1" shorter shocks
                30K miles
                http://i1228.photobucket.com/albums/...429_135845.jpg
                1981XS1100SH
                '80 G Forks and Triple Tree
                '80 G tank
                Mac Turnouts
                Virago 1" shorter rear shocks
                SH Headlight
                http://i1228.photobucket.com/albums/...psd6adaae1.jpg
                61 Wife
                83 Son
                86 Son
                89 Daughter
                • tweeleft
                  • May 2009
                  • 110
                  • Bend Oregon
                  The issue I do have is the side stand she sit a little more straight up so I have to take care parking. Good luck
                  1979 XS1100SF
                  Mac 4-1
                  Vmax bars
                  30K miles
                  1981XS1100SH
                  '80 G tank
                  Mac Turnouts
                  SH Headlight
                  61 Wife
                  83 Son
                  86 Son
                  89 Daughter
                  • XS1100carbon
                    • May 2011
                    • 137
                    • Everett, WASH.
                    shock eye size
                    Does anyone know the correct size of the eyes (10mm,12mm,14mm)for ordering new shocks?
                    • WSL91
                      • Feb 2012
                      • 427
                      • Quad Cities, IL
                      Like some of the others here my XS shocks were junk and I replaced them with XJ Shocks, the improvement is nothing short of spectacular. I can't believe how much better it rides and handles rough pavement.
                      1970? Honda Z50... gone
                      1974 Honda CB200... gone
                      2008 Honda VTX 1800F
                      http://www.johnsoldiron.com
                        • 9980
                        +1 on that.
                          • 8767
                          They are all 14MM except the lower right side mount is a 10MM.
                            With the XJ I found I needed to swap the shocks from left side to right. The rubber bushings can be pressed out and swapped from one side to another. Meanig, I would think you could press the ones out of your XS shocks and press them into the replacement shocks if need be.
                              • 9980
                              They fit just fine without swapping them if you remove the helmet lock.
