So now I am some '80 special carbs with stock jets. Got it to idle very well, can even start it with the kicker!
The problem is that I have a miss fire over 2,000 rpm. It responds to throttle very well, but if I hold it at say 4,000 I can hear it sputtering. Not terrible, but it;s there. It sounded to me just like it does when your about to run out of fuel. So last night I lowered the float heights to 21.75mm to see if that would help. It was almost midnight when I started it up to check it and I really didn't notice a change, better or worse.
Does anyone have any tips? It has the same miss all the way up to redline, but doesn't have any hesitation. I am noticing the miksfire with a load even. Like I say it isn't horrible, but if it's lean I don't even want to go down the highway at 4000 with it like this.
The problem is that I have a miss fire over 2,000 rpm. It responds to throttle very well, but if I hold it at say 4,000 I can hear it sputtering. Not terrible, but it;s there. It sounded to me just like it does when your about to run out of fuel. So last night I lowered the float heights to 21.75mm to see if that would help. It was almost midnight when I started it up to check it and I really didn't notice a change, better or worse. Does anyone have any tips? It has the same miss all the way up to redline, but doesn't have any hesitation. I am noticing the miksfire with a load even. Like I say it isn't horrible, but if it's lean I don't even want to go down the highway at 4000 with it like this.
