just double checking, the zrx1200 carbs are what i need for the swap?
zrx carbs
zrx carbs
1979 xs special, just finished the top end rebuild and then i still have lots of work.
progress thus far...
http://s1268.photobucket.com/albums/...t=IMAG0202.jpg
"If it runs bad, it's usually the carbs. If the tires go flat, I suspect the carbs. If the wind blows the bike over, the carbs were probably to blame. If my wife yells at me about something, I tell her to talk to the carbs" -IncubusTags: None -
Either the 1100 or 1200 carbs will work because they are the same carbs except for jetting. But you will have to re-jet them for your bike anyway.Mike Giroir
79 XS-1100 Special
