Oil leak between block and head. Head gasket?
  • Diskman01
    • Mar 2011
    • 263
    • Sioux Falls, SD
    Put on several hundred miles this weekend on my '78 since I finally got it dialed in and purring like a mean kitten. A cheapy $12 digital caliper made extremely short work of the carb float issues. Thanks to tat2demon sharing a spare idle mixture screw, I got the old girl running great.
    Seems to be seeping oil at the joint where the head and jug meet tho. After about 200 miles, there is(was) oil spattered all over the clutch cover, starter cover and outer carb bowls.
    Head gasket?? I checked the torque on the head bolts and they are fine. Compression numbers are fine.
    Bonus:
    Here are some pictured from today's driving around town. All the miles this weekend, 3 states and I didn't take ONE picture.
    1) Fire up Internet Explorer
    2) http://www.yahoo.com
    3) type "www.mapquest.com" into the Yahoo search page.
    4) go about day as VP managing multi-million dollar financial contracts.
    There's no oil pressure there at the head gasket, so it's not coming from there. Most likely, it's either your cam chain adjuster or valve cover leaking. Wind blows it all over the place. Wind blows the oil through the head to drip off the carb boot and right onto the top cylinder fin. When you lean the bike on it's sidestand, the oil will flow around to the front left and look like a head gasket leak between the two.
    One thing you might want to make sure of is to pull the left and right side covers and make sure it isn't a crank seal leaking.
    • Diskman01
      • Mar 2011
      • 263
      • Sioux Falls, SD
      Ok.. I replaced the CCT about 2 weeks ago... Thought I gasketed her up enough.. Will go doublecheck that area. Not sure if there was pressure at the head/block joint or not.
        hopefully U used shorter allen bolts with the swap, plus, have seen some head castings where there is a casting edge that'll catch the auto tensioners and you think it is pulled down tight. Somethin' you might check also.
        • Diskman01
          • Mar 2011
          • 263
          • Sioux Falls, SD
          The area around the CCT is dry as a bone. It's the ends of the block/head that are seeping oil. Valve cover gasket is dry too....
          Odd..
          • tcoop
            • Nov 2009
            • 793
            • South Weber, UT
            My first XS11 I thaought I had a head gasket leak. I pullled the head (gasket was fine) put it back togeather and bent a valve (did a lot of things wrong). Found that the leak was comming from the inner part of the valve cover and running out the air pass through holes (not sure what they are called) in the head.
            Ty
            78 XS1100E - Now in Minnesota
            80 XS1100LG - The Punisher
            82 XJ1100 - Daughter's Bike
              • 9980
              Check all around the valve cover, it's probably leaking on the inside between the cams.
              Those are drain holes so the spark plug wells don't fill up with water........
              or oil. They drain just above where the head meets the cylinders, where the head gasket is.
              • WSL91
                • Feb 2012
                • 427
                • Quad Cities, IL
                Nice bike!
                1970? Honda Z50... gone
                1974? Yamaha 100 Enduro... gone
                1974 Honda CB200... gone
                1981 Yamaha Virago 750... gone
                1993 Honda Shadow 1100... gone
                2008 Honda VTX 1800F
                1982 Yamaha XJ1100J w/850 final, Raptor ACCT
                1979 Yamaha XS1100SF "Chewey" Raptor ACCT
                http://www.johnsoldiron.com
                  • 5062
                  I had a leak on one of my 78's near the contact of the head to the jugs. It was an annoying seep. I think it may have had something to to with an oil return passage. I cleaned it with carb cleaner and applied some RTV Black and the seep stopped. It was on the right side at the rear. I don't know, but I think there is a plastic sleeve for the head bolts and if that one is broken, maybe that is the source of the leak? All I can say is, the RTV did the trick.
                    All oil return is through the timing chain tunnel, oil going to the head comes only from the metal line that runs up the rear center of the cylinders. So the only leaks possible are from the valve cover, banjo bolts on the oil line, cct, or a bad head gasket at the timing chain.tunnel (unlikely though).
                    Or I guess if there was a crack in the head that hit one of the pressurized passages that flow to the cam journals, but I don't see that happening.
                    • mack
                      • 2411
                      • Ontario, Canada
                      Torque
                      Check the torque on the head bolts.
                      mack
                      79 XS 1100 SF Special
                      HERMES
                      original owner
                      81 XS 1100 LH MNS
                      SPICA
                      78 XS 11E
                      IOTA
                      https://youtu.be/wB5Jfbp6SUc
                      https://youtu.be/RaI3WYHSuWA
                      Frankford, Ont, Canada
                      613-398-6186
                      • mack
                        • 2411
                        • Ontario, Canada
                        oops
                        Missed that on your first post. Sorry, disregard.
                        mack
                        HERMES
                        original owner
                        81 XS 1100 LH MNS
                        SPICA
                        78 XS 11E
                        IOTA
                        613-398-6186
