stock cam chain tension adjustment
  • 650mark
    • Jul 2012
    • 307
    • Mesa, Az.
    is it necessary to remove the rubber plug and push in on the tensioner to correctly adjust the cam chain tension? the factory manual says nothing about removing the plug during the adjustment procedure but one of the more experienced guys on this forum says that i need to. i believe he certainly knows what he's talking about but i'm curious as to why the book misses this step. any other opinions? thanks from a newbie
    Experienced?..................actually clueless. The plug is supossed to be permanently in there so oil doesn't leak out. No pressure there, but still will leak there. If you been reading any recent threads, you'll see a couple folks so far that chose NOT to swap out the POS stock tensioner for one of the auto tensioners......results......bent valves. Keep pushin' your luck and your bike WILL be amongst them. BTW, in the future, any questions, ask some of us here who have had and been around these scoots since their conception and longer. Will save yourself alot of unnecessary grief.......just sayin'....
      +1 on what moto says. Leave the plug alone, and SERIOUSLY start looking for an auto tensioner. You can still find them real cheap.
      Just today someone found 2 bent valves after he pulled the head cause his stock tensioner gave up.
        With those OEM tensioners, I have occationally pushed in on the plunger with a screwdriver when adjusting to make sure it is not siezed/frozen in place and is actually capable of taking slack out of the chain. If there is zero movement, it is either stuck/gummed up or at the end of it's travel range. It is good piece of mind, JMHO. By all means when you get the chance, upgrade to the auto unit, set it and forget it, and they won't ever leak oil.
        • James England
          • 3039
          • North of England
          Get rid of it. They're rubbish. The auto CCT is the way to go. Get one from a V-Max... there's two on those bikes and they go straight on, without having to elongate one of the mounting holes.
