Question for those using an oil cooler.
  • Cobia
    • Jul 2007
    • 1587
    • Palm Beach County, Fl
    How much 'extra' oil, if any, do you have to put in the bike as a result of having the additional plumbing for the oil cooler ?
    Is there a 'recommended' ammount ?
    1980G Standard, Restored
    Kerker 4 - 1
    850 Rear End Mod
    Automatic CCT
    1980GH Special, Restored
    '82 XJ1100 (Sold)
    Top mark on the site glass.
      Hi Cobia,
      First time it will take 1/2 a liter or so after that it's just a normal oil change. Fill to the top of the glass and run for a few minutes then top up.
      Maxim Phil
      • Cobia
        • Jul 2007
        • 1587
        Thanks guys. Got it.
        Kerker 4 - 1
        850 Rear End Mod
        Automatic CCT
        '82 XJ1100 (Sold)
          Right out of the original yellow owners manual, 81H(yours will be the same with cooler)4.4US quarts...........81SH, 4.2US quarts. Those capacities are with filter change. For others in question or dispute.......it don't get much simpler than that. That extra for the Standard just covers the sight glass.
            I wonder what the extra .2 quarts for the standard is from since the motors below the cylinders where the oil goes are all the same?
            • jwhughes3
              • 2798
              • Home of the Alamo
              The 81H had a standard oil cooler.
              John
              '81 XS1100H - "Enterprise"
                trbig, I would imagine in order to have a 'running' level in the pan that was considered enough to keep pick-up tube/screen safely submerged, the bit of extra oil would compensate for the small capacity of the oil cooler and additional hoses.
                  • 3193
                  JAT but maybe the extra oil has to do with the slightly different stance of a standard vs a special. Dunno myself but I always start and run it then check the sight glass so I am not sure how much I put in it.
