Cam Chain Life
  • MPittma100
    • Aug 2011
    • 2359
    Cam Chain Life
    I have seen a lot of posts about worn cam chains on the site.
    Wondering if anyone has any experience on when these chains wear out as far as time/mileage.
    MP
    1981 XS1100H Venturer
    K&N Air Filter
    ACCT
    Custom Paint by Deitz
    Geezer Rectifier/Regulator
    Stebel Nautilus Horn
    EBC Front Rotors
    Limie Accent Moves On In 2015
    Mike
    I have 65K miles on mine, never been changed. I have the auto cam chain tensioner which extends the normal service limit of the chain a bit as opposed to the stock unit which runs out of travel/adjustment sooner.
      50K, mine was toast. YMMV
      • CaptonZap
        • Jun 2010
        • 1748
        • Denver
        With or without the automatic tensioner? CZ
        • 650mark
          • Jul 2012
          • 307
          • Mesa, Az.
          so, if an xs1100 owner is somewhat maintenance intensive and adjusts the cam chain regularly does that eliminate the "need" for an automatic tensioner?
          do the stock chains/tensioners fail routinely simply from mileage or from neglect?
            The ACCT eliminates the "need" for adjustment and yes the stock tensioners fail/slip routinely due to design. Not to mention leak oil.
              Just from a physics standpoint, I would say that keeping it adjusted would prolong its life. Less flapping around means less movement against the chain pins.
                That was with the stock tensioner. I bought an ACCT. When I removed the original unit, I discovered it was fully extended.
                • CaptonZap
                  • Jun 2010
                  • 1748
                  • Denver
                  Are you the original owner? Do you know what oil change intervals, and what oils were used from the time it was new?
                  All of these things have a bearing on chain life, and to get a good idea of how long a chain will last would require a comparison of all the variables associated with the life span of the chains.
                  So far, you're the benchmark.
                  Thanks for the input, CZ
                  • Eveready1100
                    • 539
                    How much extra travel does the ACCT provide? I recently discovered that some brands of aftermarket cam chains are a couple off mm longer than the OEM ones. Might be able to get some more life out of them instead of losing a lot of travel on the initial adjustment.
                    • jwhughes3
                      • 2798
                      • Home of the Alamo
                      IIRC I want to say about .25" longer plunger.
                      John
                      '81 XS1100H - "Enterprise"
                        I bought the bike with 10K on it in 2003. My oil changes are irregular. I sometimes change it at 1500 miles and sometimes almost 4K. I have used a good bit of Mobil 1 and Shell Rotella. Until recently, I've been using Yamalube. Right now it has Valvoline 20W50 motorcycle oil in it that I bought on sale.
                        I often ride hard in the mountains. I like lots of RPM and on and off the throttle. I'm very often two-up as well.
                        The ACCT I bought has less travel than the OEM unit. I don't remember how much less. I bought an EK chain from Z1 Enterprises. After installation, it's tight enough to run with no tensioner. (No, I didn't try it)
