Slipping
  • wileys wheels
    • Feb 2003
    • 1
    • N.FOND DU LAC WISCONSIN
    Slipping
    I have a 1979 xs1100 Special, when in high gears, i give it gas to pass, and it slips, but only at high throttle and higher gears, any thoughts.
  • TADracer
    • May 2006
    • 1417
    • Kenner, Louisiana USA
    New set of clutch springs should solve the prob. A fairly cheap fix and easy to do on the side stand without even draining the oil.
    Mike Giroir
    79 XS-1100 Special
    • buffalo
      • Aug 2002
      • 141
      • Carson City, NV.
      Are you aware there is an adjustment down on the clutch as well as on the cable? I would try that first. Otherwise you may need springs or new plates.
      buffalo
      80 XS1100SG
        Barnett clutch spring. Don't waste your time with EBC springs.
        • Gallaecus
          • May 2011
          • 254
          • East Haven Connecticut
          my clutch was doing the same thing because i used 10w40
          when I should have used 20w50
          and also what these guys say above....
          Steven
          1981 XS 1100 LH
          1979 XS 1100 SF
          • Aches n Pains
            • 349
            • Reston, Va.
            +1 on the oil. And don't use synthetic for the same reason.
            1995 KZ100P
            Pods, jets, pipes, cam adjuster, oil cooler
            1977 Ironhead - custom build
            Hot engine, custom frame, KZ front and rear, high torque starter, alternator conversion, Progressive shocks, Thunderheart wiring, Dyna ignition, oil cooler, Dakota Digital instruments, etc.
            Sold all my XS's to Eastcoaster but still love to keep up with you guys. This is the best cycle forum on the web.
