I gleaped a couple of pictures from Don Glarden's (DGXSER) page for the Honda coils he found:-
XS11.com Forums > Idle Talk Forum > XS11/XJ11 Discussion > Honda Coils Modification
For those of you interested in coils with replaceable plug wires, good performance, and an easy fit on the XS1100, here is a brief how to for installing the Honda VF1000R coils. I want to give credit to the UK forum for documenting this mod years ago.
First, these are 3 ohm coils, so if you have the 78-80 model bikes, you will need to remove the ballast resistor. Just pull the connectors out and plug the two connectors from the harness together.
Here is a close up of the coil with the part number stamped in it.
Just push the wire into the coil making sure you push it all the way onto the spike. Now push the seal down and tighten the cap onto the coil. Here is the coil ready to be installed.
