78 XS11 Float Height HELP.. Yes, I searched..
  • Diskman01
    • Mar 2011
    • 263
    • Sioux Falls, SD
    Ok.. Can someone PLEASE tell me how to measure the floats in my 78 11?
    I have read SOOO many conflicting ways that I am ready to throw down for fuel injection (ha!).
    I have the BLACK plastic floats (Are they supposed to be brass?).
    I understand that I need to measure from the GASKET SURFACE with gasket removed to the TOP of the float.. I have seen 2 ways now..
    I drew up a pic..
    The way I *HAVE* been adjusting is to the TOP of the float marked with the RED ARROW.
    Now, I have read that its the top of the ROUND part as marked with my GREEN arrow.
    AND, that I need to start at 22MM since they are plastic?!?
    I have lost count as to the times I have removed the carbs to adjust this. I can remove them in about 1 minute now (pods).
    What is the CORRECT point to measure on the float please and is it REALLY 22MM for these??
    1) Fire up Internet Explorer
    2) http://www.yahoo.com
    3) type "www.mapquest.com" into the Yahoo search page.
    4) go about day as VP managing multi-million dollar financial contracts.
    Green arrow, and 23mm.
    Are your carbs early or late model carbs?
      Start at 23MM with plastic floats and see how it runs.
      • CaptonZap
        • Jun 2010
        • 1748
        • Denver
        Don' get to anal about it, the manuals give a float height that is plus or minus a millimeter, so get them all the same, and see if it is rich or lean, and adjust from there. CZ
        • 79XS11F
          • 3563
          • Ottawa, Ont. Canada
          Measure from the highest point on the actual float to the gasket surface of the carb body where the carb bowl would meet the carb body WITH THE GASKET REMOVED. The measurement should be to the specs in the manual for the carbs in question. Often times the carbs on a bike will not be true to that model. Digital calipers is the easiest way to do it. Make sure both floats are the same in each carb and each pair of floats are the same from carb to carb.
          Rob
          KEEP THE RUBBER SIDE DOWN
          1978 XS1100E Modified
          1978 XS500E
          1979 XS1100F Restored
          1981 Suzuki GS1100
          1983 Suzuki GS750S Katana
          1983 Honda CB900 Custom
            Actually it should be for the float being used. Plastic floats in early carbs still use the later spec of 23mm and brass float in late carbs would use the early spec of 25.7mm.
            Brass floats use 25.7mm
            Plastic floats use 23mm
            • mikubuilder
              • Jul 2011
              • 548
              • Westland, Mich.
              and make sure that BOTH float halves are at the same height....
              Nick
              1982 Virago 750 (it's alive!)
              • Diskman01
                • Mar 2011
                • 263
                • Sioux Falls, SD
                Alrighty. The correct answer was...
                Removing the float needle seats and needles and polishing the seats with a Q-TIP and toothpaste in a cordless drill.
                Pretty sure my driveability issues have been related to the float needles not seating sometimes. THAT would explain my intermittent RICH/LEAN conditions. I don't think the gas flow was shutting off 100% at times. Telltale signs were yellow gas residue on the engine side of the carb outlets continuing underneath.
                The seats polished up EXCELLENT with the q-tip and drill. They were pretty grungy before.
                Test ride seems to have REALLY leaned out#2 and 3 finally. 1 and 4 will be addressed with the idle mixtures or maybe more float tweaking. Who knows.
                • Aches n Pains
                  • 349
                  • Reston, Va.
                  I use a float gauge which gets everything close and level. Very easy to use and not very expensive.
                  http://www.amazon.com/CARBURETOR-FLO.../dp/B001PLDUVE
                  1995 KZ100P
                  Pods, jets, pipes, cam adjuster, oil cooler
                  1977 Ironhead - custom build
                  Hot engine, custom frame, KZ front and rear, high torque starter, alternator conversion, Progressive shocks, Thunderheart wiring, Dyna ignition, oil cooler, Dakota Digital instruments, etc.
                  Sold all my XS's to Eastcoaster but still love to keep up with you guys. This is the best cycle forum on the web.
                  • Diskman01
                    • Mar 2011
                    • 263
                    • Sioux Falls, SD
                    I used an old library card I had in a drawer. Measured out 26MM and went to town.
                    Got it running pretty well now! Need to do a final sync yet.
