Won't run when wet, Dies when put in gear - Solution
    • 2104
    Hey Greg, my nickname at work is Johnny Overkill go figure huh.
      Don't know if it has been mentioned, if you're stuck somewhere in the rain, you can disconnect the neutral wire and ground it under a nearby shifter cover bolt so it will hit on all 4 and get you on your way, BTDT.
        Yeah, you mentioned that some time ago. Good thing to know in a pinch.I had no wrenches at the time...figures!
