Idle Mixture Screwed
  • conquest87tsi
    • Jun 2012
    • 190
    • Jackson, Minn.
    So I recently replaced my float needles, cleaned the carbs, set float heights, and resynced. I was in the process of setting the idle mixture last night and encountered some problems.
    I chose to use the propane leak method to adjust the mixture. On the two of the carbs this worked great and I was able to set the mixture where the idle jumps slightly with a small amount of propane, however, on two of the carbs there is no change when propain is introduced, and no change when the screws are adjusted in anyway.
    The two problem carbs are not paired and I have black smoke out of both exhaust pipes. The bike idles pretty good, and it will idle smoothley as low as 900-1000 rpm. But if I throttle up smoothly it will hicup around 4,500 rpm and above. And smoke a lot.
    I removed all of the mixture screws and discovered the two problem carb's needles have wear grooves worn into them, while the ones I could adjust are just fine. Just for the hell of it I started the bike with the needles removed and it actually ran very well, without the 4,500rpm miss.
    Now the question:
    Should I just the replace the mixture needles? Is this my main problem? When removing the screws does this create a lean condition? Can anyone give me more info on the screw, is in = rich and out = leaner?? Not sure how it works exactly. If I just need to replace the screws, does anyone know if it's true that 76-77 XS650 needles will fit?
    Any help is greatly appreciated. Should have never started tearing apart the carbs until after the summer.
    1979 XS1100 SF
    1979 XS750 SF
    Previous Rides:
    1981 KZ650CSR
    2006 VTX 1300C
    1986 Radian 600
    Not sure what you mean by using propane to adjust the mixture screws. Only thing to use.propane for is to look for vac leaks. If you have a rise in.rpm then there is a vacuum leak than needs to be fixed.
    I would replace the needles if there are groovs.
    Get her put together and bring it to the lost rally in central WI this weekend. We will help ya out!
    • conquest87tsi
      • Jun 2012
      • 190
      • Jackson, Minn.
      Propane
      There was a How To on setting the idle mixture that I found on here. It said to leak a calibrated amount of propane into each carb boot. If idles up too lean, if down to rich. Anyone use this method?
      1979 XS1100 SF
      1979 XS750 SF
      Previous Rides:
      1981 KZ650CSR
      2006 VTX 1300C
      1986 Radian 600
        I would be interested to see that! But how do you calibrated the propane?.......
        • conquest87tsi
          • Jun 2012
          • 190
          • Jackson, Minn.
          Propane
          Use the same flame size on each carb. With the flame extinguished of course.
          1979 XS1100 SF
          1979 XS750 SF
          Previous Rides:
          1981 KZ650CSR
          2006 VTX 1300C
          1986 Radian 600
          • Tat2demon
            • Jun 2012
            • 718
            • Sioux Falls, South Dakota
            Here Nate. One of the tech tips.
            Nate
            78 XS11 "Matilda" 2H7 000364
            K+N Air Filter
            88 Voyager XII
            81 XJ650 Maxim
            • mikubuilder
              • Jul 2011
              • 548
              • Westland, Mich.
              that's pretty cool and DIY friendly
              Nick
              1982 Virago 750 (it's alive!)
              • conquest87tsi
                • Jun 2012
                • 190
                • Jackson, Minn.
                She don't lie...Propane
                It actually is pretty easy, well when the mixture screws are actually doing something. So I set the carbs per the tech tip, and it still seems to be running rich. I know I need to replace the mixture screws/needles, but is there something else I'll need to do? Or should I be able to get it tuned with the new mixture screws?
                1979 XS1100 SF
                1979 XS750 SF
                Previous Rides:
                1981 KZ650CSR
                2006 VTX 1300C
                1986 Radian 600
                  Are you using an external tach when doing that? The OEM tach would be worthless for that!
                  I would think that is you can remove the screws and you get no real measurable change then you may have screws tips broken off in the holes.
                  • conquest87tsi
                    • Jun 2012
                    • 190
                    • Jackson, Minn.
                    Mixture screw
                    As I said before, I completely removed the screws and they are complete, however there are grooves worn in two of them.
                    1979 XS1100 SF
                    1979 XS750 SF
                    Previous Rides:
                    1981 KZ650CSR
                    2006 VTX 1300C
                    1986 Radian 600
                    • GLoweVA
                      • Jun 2011
                      • 1957
                      • Virginia Beach, VA.
                      Are the grooves spiral? I would think as they get screwed in and twist as they go in, then whatever has caused the 'groove' would cause it to 'spiral' as it goes in.
                      As they say, a picture is worth a thousand words...... Pic Please...
                      I just noticed your login name... My Brother had an 87 Dodge Conquest.! (actually his was the Mitubishi Starion, but same thing) Wow did that car fly. I wish I could have gotten that car from him. Instead I ended up with a Honda Prelude
                      80G (Green paint(PO idea))
                      The Green Monster
                      Got him in '04.
                      bald tire & borrowing parts
                      Scarlet
                      Got her in '11
                      Ready for the twisties!
                      81H (previously CPMaynard's)
                      Hugo
                      Cold weather ride
                      • conquest87tsi
                        • Jun 2012
                        • 190
                        • Jackson, Minn.
                        Connie
                        Yeh, I don't think I'll ever get rid of mine. We were both born on the same year even. Bought her six years ago when she had 80K on the clock, about 110k now I think. I love the car, got hit my a blonde in a grand am in the drivers quarter, sat pretty much since.
                        1979 XS1100 SF
                        1979 XS750 SF
                        Previous Rides:
                        1981 KZ650CSR
                        2006 VTX 1300C
                        1986 Radian 600
                          You could be bottoming out on a screw tip, they aren't that large. You gotta look and see. You would have a good vacuum leak if you remove that screw so there should be a change in how it ryns.
                            That was the carb. adjusting procedure in the late 70's early 80's on carb related chryslers. Doing a 'lean drop' using propane when setting idle mix screws Nate.
                              • 5051
                              Boy! Your floats must be set awfully high to be able to run with the pilot screws out. The carbs would be sucking in air to lean what would be an overly rich mixture. At least that is my best guess.
