Hello all! A brief "excuse" first...I'm a former Auto Tech of 25 years who made the switch to prison guard, so shift work and on-call duties have severely limited my available diagnostic time. I thought I'd ask here 1st in case this was a common problem.
My 1980 XS had a complete going over 2 years ago: new tank, COMPLETE carb rebuilds, as well as rebuilt petcocks and new strainers, etc, etc.The bike ran fantastic and ran that way when parked last year. I always drain the tank and carbs for storage and bring the battery inside. After a new battery and a tank of fuel, the season's first start was disappointing...It fired up right away on full choke, but when I put it on the second step of the choke to lower the rpm- it stalled like someone shut it off with a switch. It restarted fine, but stalled the same way when I cracked the throttle. It won't run without the choke- no idle and every time I crack the throttle it "lean pops" in the airbox and stalls. Fuel delivery to the carbs is good and whenn I pulled the rack of carbs out and checked for debris or plugging of jets I found the carbs to be as clean as after the rebuild. My spark tester shows that it doesn't lose spark either when it stalls. It seems to be a fueling issue, but I'll be hanged if I can see where the problem is. When set to full choke, it will run by itself but stalls if I even think of opening the throttle. The carb intake boots are new as well and I checked for vacuum leaks and found none. I know it's not engine internal mechanical problems like hanging valves as it ran fine when parked and has great cranking compression and runs smooth on full choke. It seems super lean, but I'm not sure why. My time to rip and tear is limited since our justice system and crime rate leave me with almost no free time at all. Any tips would be appreciated...I can't keep pulling the carbs for no good reason other than to practice cussing...amd I need no help in that department!
Thanks for looking....
I hope you've read thru the carb tech tip and learned that you do NOT want to soak the actual carb bodies...at least not in any caustic carb cleaner. I meant soaking the metal parts removed from the carbs only! Hope you didn't/haven't soaked the carb bodies in carb cleaner, otherwise damage to the butterfly shaft seals will occur!
