now that i finally have a carb sync tool. i need to know where to hook it up. is it to the carb boots? or is there a port on the actual carbs?
carb syncing question
1979 xs special, just finished the top end rebuild and then i still have lots of work.
progress thus far...
http://s1268.photobucket.com/albums/...t=IMAG0202.jpg
"If it runs bad, it's usually the carbs. If the tires go flat, I suspect the carbs. If the wind blows the bike over, the carbs were probably to blame. If my wife yells at me about something, I tell her to talk to the carbs" -IncubusTags: None
The carb boots. Each one has a nipple and a cap or hose on it.
If you've got a standard, #2 & #3 petcocks hook up there.
If you've got a special, #2 is hooked up to the 'octy'/fuel valve.
Hook up your sync rig to those 4 ports.
Make sure you've got the gas on prime, otherwise, you'll run out of gas because either the petcocks won't flow or the fuel valve(octy) won't.
the only port on the carbs is #2 for the vac advance line.Hi, my name is George & I'm a twisty addict!
80G (Green paint(PO idea))
The Green Monster
Got him in '04.
bald tire & borrowing parts
Scarlet
Got her in '11
Ready for the twisties!
81H (previously CPMaynard's)
Hugo
Cold weather ride
The carb boots...Fast, Cheap, Reliable... Pick any two
thanks guys, should be running great soon1979 xs special, just finished the top end rebuild and then i still have lots of work.
Originally posted by Shockman54 View Postthanks guys, should be running great soonNathan
