New coil assistance
  • JCruze
    • Aug 2011
    • 32
    • San Francisco, CA
    New coil assistance
    So I have a 78 xs1100 and I'm looking for some new coils. I believe I have found the pair I want here z1 enterprises
    From what I've read so far I should aim for something in the 3.0 Ohm range- which makes sense. But I also see some talk about removing the ballist resistor. Why would you need to do this? Considering my bike has one I figure it's something I need to know more about. Thanks!
    Also, I'm taking suggestions for new ignition wires if anyone knows of a good set.
    ___________________
    Dyna Coils
    16'' Rear Wheel
    4-1 Exhaust
    Kerker Muffler
    Firestone Deluxe Champion Tires
    Custom Seat and Fender
    Those are the correct coils. Shop around, you can find them cheaper usually.
    The XS runs a 3 ohm ignition system, so that is where that number comes from. For the '78-'80 models they used 1.5 ohm coils and a 1.5 ohm ballast resistor to archive the needed 3 ohms. So when you upgrade to the 3 ohm coils you need to eliminate that 1.5 ohm resistor.
    Wire, any solid core wires work. Carbon core is too fragile for this application (yeah I know there are a couple that use them but let's see whos wires last longer!).
      Nate hit it on the head on the ballast resistor and the 3 ohm system.
      As for wires, I just went through this. Every auto supply house I went to only had the carbon fiber type wires which I could not get to work well for me. I went to Z1 IIRC and bought the red 7MM solid core wires. Working great for me.
      • JCruze
        • Aug 2011
        • 32
        • San Francisco, CA
        Cool, thanks guys. Very helpful as always.
        ___________________
        Dyna Coils
        16'' Rear Wheel
        4-1 Exhaust
        Kerker Muffler
