I have mentioned this before in other threads, BUT...
This is not a huge problem, but after searching the forums, I have a couple of questions.
At a tach-indicated 1100-RPM idle my turn signals don't like to flash, they just hold on steady. A slight increase in RPM fixes this. I have never had any problem with the charging system, checked it recently and found it to be completely fine. My fuse box (original) is clean and corrosion free. My battery hasn't died even once in 4 years.
In other threads i have read about Geezer's Reg/Rec and also fuse box replacement as being solutions to low RPM power problems. Is this flashing problem unique or a fairly common thing, and in your opinion is it worth replacing the original parts, even if they work 'fine,' to fix this issue.
Thanks.
Thanks.
