Topped out...
  • WMarshy
    • Apr 2009
    • 2402
    • Mexico NY
    Topped out...
    Topped out and cant reach redline in 5th gear... The other night I had a 90's Cadillac walk away from me and it left me wondering (among others) why cant I reach redline in 5th gear? My valve clearances are within spec now and the bike pulls strong in ever gear right to redline except 5th. It just seems to hit a wall and wont pull anymore then about 7300 RPM in 5th. When at WOT does carb sync come into play? Any advice to get the last drop? When I get a change Im going to pull the carbs and check float height.
    '79 XS11 F
    Stock except K&N
    '79 XS11 SF
    Stock, no title.
    '84 Chevy K-10 "Big Blue"
    Main Jets are the only other idea I have. You really are relying on those jets at that RPM. But float height will make a difference.
    Well, spark can play a part, if your coils are slightly weak you could not be getting a hot enough spark to give full power at that point.
      • 9980
      That's about 120 mph Wade. How fast do you want to go?
      • WMarshy
        • Apr 2009
        • 2402
        • Mexico NY
        I dont know the answer to that question yet Greg.
        '79 XS11 F
        Stock except K&N
        '79 XS11 SF
        Stock, no title.
        • jwhughes3
          • 2798
          • Home of the Alamo
          Drop the ballast!
          I think the thing that slows me is the "sprung" weight I carry
          Of course I usually only drive no faster than 65 mph!
          John
          '81 XS1100H - "Enterprise"
            Even when brand new, these bikes topped out at about 135, and getting that last 10-15 mph took some distance. My '78 could pull to a bit over 135 indicated (probably about 125 actual) in fifth, but it took at least a mile to get the last 10 mph....
            This was 1978 when I was still sure I was bulletproof...
            • James England
              • 3039
              • North of England
              100% ditto. Same with my new 79. I did exactly the same thing.
              It seems to me that asking for more than 120mph on a bike of that age is asking for trouble.
              BTW Steve, I feel a poll coming on.......
                The only thing I have to add is something I read on here some time ago. To get the maximum pull out of it, never let the RPMs drop below 5k, even between shifts.
                • old_chopper
                  • Sep 2010
                  • 120
                  • Oklahoma
                  Pushing a lot of air once you reach triple digits. I had my '03 V-Rod reading 135 and it was a chore to stay on it, forward controls are not made for that! My XS is my work truck, it's not safety tested for those speeds!
                  US Army 1986-1991
                  1979 1100 Special (on the road after 16 years!)
                  1983 GS300L (wifes ride)
                  1985 Super Glide
                  2012 Super Glide
                    • 9980
                    I've gotten about 125 out of mine in the right conditions. I had to shift down to 4th though because I have the FD mod. In 5th I can only get about 105.
                    That's a lot of wind resistance for these old carbureted work horses the overcome. They aren't really aerodynamic.
                    • daveyg
                      • Feb 2009
                      • 411
                      • Boise, ID
                      Easy, just add some n2o! 20mph at the push of a button!
                      BARE BONES CHOPPERS: If it don't make it go faster, you don't need it!
                      80 XS1100SG(cafe in progress *slowly)
                        my 2cents. Even race cars do not pull redline in top gear.
                        XS max horsepower is at around 7200rpm. Horsepower is what gives you speed. Less weight and no wind would help to go faster.
                        Were you tucked in over the tank or sitting up like a barn door
                          • 3182
                          The exhaust you may be running is also a factor in this equation. I have found that 4 into 1 is different than a 4 into 2 for aftermarket exhaust. I had no problem with the 135mph with the stock exhaust but find that my Jardine spaghetti's will run out of steam before that. I still will try another bigger set of jets to see if that corrects it but getting up to 145 mains just seems like it will cost me mileage.
                          • petejw
                            • 2269
                            • sydney australia
                            u could try bumping up the main jet
                            by a size or 2 and make sure ur float
                            heights arent adjusted on the leaner side
                            of stock.
                            pete
                            new owner of
                            08 gen2 hayabusa
                            former owner
                            1981 xs1100 RH (aus) (5N5)
                            zrx carbs
                            18mm float height
                            145 main jets
                            38 pilots
                            • WMarshy
                              • Apr 2009
                              • 2402
                              • Mexico NY
                              Phil, I was up like a barn door.
                              I have the stock 4-2 installed currently... I think its time to check the float height. I think we both could stand to lose a few pounds, I just wish I could unbolt mine.
                              I have been trying to snipe a set of those Accel coils, Im sure the original ignition wires are at the end of their life...
                              '79 XS11 F
                              Stock except K&N
                              '79 XS11 SF
                              Stock, no title.
