Vacuum Gauges
  • Vacuum Gauges
    The set of gauges I got came with a couple sets of brass tubes. The instructions say to hook the tubes to the vac lines then screw into the intake. Do I skip the tubes and just put the rubber vac lines on the intake nipples?
    Nate
    78 XS11 "Matilda" 2H7 000364
    K+N Air Filter
    88 Voyager XII
    81 XJ650 Maxim
    yep u dont need those rods,
    ull need some sort of restrictor in the line tho
    to stop the needles from bouncing,
    also be sure to calibrate the guages.
    pete
    new owner of
    08 gen2 hayabusa
    former owner
    1981 xs1100 RH (aus) (5N5)
    zrx carbs
    18mm float height
    145 main jets
    38 pilots
      Ok well that kinda pisses me off. The ebay listing for it said the extra tubes are needed for the XS1100. Costs an extra $10 for something I dont need. It has the little valves for restriction. I hooked them all up to aquarium air pump T's and sucked on the line. They were all exact.
      Thanks a lot.
      Nate
      K+N Air Filter
      88 Voyager XII
      81 XJ650 Maxim
        have u got a link to the ebay listing nate?
        pete
        new owner of
        08 gen2 hayabusa
        former owner
        zrx carbs
        18mm float height
        145 main jets
        38 pilots
          http://www.ebay.com/itm/330727802667...84.m1497.l2649
          After re-reading, it doesnt say XS1100 specifically. Just that you need it for Yamahas.
          Nate
          K+N Air Filter
          88 Voyager XII
          81 XJ650 Maxim
            I bought the gauges, then saw that I needed an adapter. I messaged them saying I needed the adapter for a Yamaha. He billed me $10 and added the other set of tubes in the kit.
            Nate
            K+N Air Filter
            88 Voyager XII
            81 XJ650 Maxim
              no u dont need them,
              but ull need a restrictor in the hoses,
              they usually come with 4 aquarium valves
              so u can restrict the vaccuum to stop the needles
              from bouncing, cant see them in the pics
              did they come with them?
              pete
              new owner of
              08 gen2 hayabusa
              former owner
              zrx carbs
              18mm float height
              145 main jets
              38 pilots
                Yeah they're included. Ive already synched twice but wanted to make sure I wasn't messing something up by not using the tubes.
                Nate
                K+N Air Filter
                88 Voyager XII
                81 XJ650 Maxim
                  no worries, all good.
                  pete
                  new owner of
                  08 gen2 hayabusa
                  former owner
                  zrx carbs
                  18mm float height
                  145 main jets
                  38 pilots
