No Headlight or taillight
  • tcoop
    • Nov 2009
    • 793
    • South Weber, UT
    On the LG that I am building I used a SF wiring harness I have everything working except the Headlight, taillight and lights on the gages. I do not have the light check unit (not sure what it is called) I have one coming in on Friday.
    Would this unit keep the lights from working? Or do I need to be looking for something else? From the looks of the Wiring diagram it only turns on the oil light if something is not working properly.
    The bike runs, turn signals work, brake lights work and the nutral light works. I replaced the fuse box with a blade type box. The fuses are brand new and are the 'Smart Fuse' that lights up when is is blown. They all look fine.
    Ty
    78 XS1100E - Now in Minnesota
    80 XS1100LG - The Punisher
    82 XJ1100 - Daughter's Bike
  • tcoop
    • Nov 2009
    • 793
    • South Weber, UT
    found the issues. The headlight was not working because of a bad headlight relay (the relay just above the coils), the tail lights were not working because of the missing Light check unit. Now everything is working.
    Ty
      • 8962
      Glad you got it sorted out. Just for future reference if needed...
      Wiring Bypass:
      Light Checker Unit : Unplug unit and connect blu and blu/yel together at the harness plug.
      Headlight Relay : Unplug unit and connect red/yel and blu/blk together at the harness plug.
      Reserve Lighting Unit: Unplug unit and connect blu/blk and blu/yel together at the harness plug.
      • tcoop
        • Nov 2009
        • 793
        • South Weber, UT
        Thanks, thats good to know.
        Ty
